#6391 Post by RESET_9999 » Thu Apr 21, 2022 7:01 pm
thanks, @quietvoid for confirming, that is what I expected.
IMO it is better to convert any itunes/appletv profile 5 DV to profile 8 .
staknhalo
#6392 Post by staknhalo » Thu Apr 21, 2022 9:19 pm
yeah i wonder why they're doing it then if intentional or if they even know they are
drew_nickel
#6393 Post by drew_nickel » Thu Apr 21, 2022 9:44 pm
@reset_9999
I'm sure you have already covered this, but whats the benefit of converting to profile 8?
#6394 Post by RESET_9999 » Thu Apr 21, 2022 11:29 pm
@reset_9999
for the itunes web-dl = better and more accurate colors
for everything else = just personal preference because I have TVs that don't support DV
staknhalo
#6395 Post by staknhalo » Fri Apr 22, 2022 3:44 am
I also found another very niche reason but applicable to me - if you use Phillips Hue lights and Hue Sync with your TV (I use Hue Essentials on my Shield in lieu of an official Sync Box) - it works with unprotected DV content like through Plex but it samples just the base layer without any of the color transformation in the DV metadata so it incorrectly just mimics red and greens for p5 files, for p7 and p8 files with HDR10 base layer, appropriate matching colors are output
redoine322
#6396 Post by redoine322 » Fri Apr 22, 2022 11:19 am
@reset_9999
What about Tvs that support Dv ( i have Lg C1 ) what is the Best Profile @reset_9999
#6397 Post by RESET_9999 » Fri Apr 22, 2022 12:47 pm
itunes: P8
the rest: P5
redoine322
#6398 Post by redoine322 » Fri Apr 22, 2022 12:52 pm
itunes: P8
the rest: P5
thanks How i can get that with your Script Plz From BDMV thanks again for the Help @reset_9999
#6399 Post by RESET_9999 » Fri Apr 22, 2022 1:40 pm
all this talk is about WEB-DL from streaming services. From a BD source, you'll always get P8 or P7 depending on the workflow you chose.
redoine322
#6400 Post by redoine322 » Fri Apr 22, 2022 1:55 pm
understood ... is there any deference between P5 and 8 ?
#6401 Post by RESET_9999 » Fri Apr 22, 2022 2:20 pm
P5 use a more efficient colorspace
redoine322
#6402 Post by redoine322 » Fri Apr 22, 2022 2:37 pm
is there any way we can get a P5 ? just wanna get the best out of My new Tv :lol: :lol:
#6403 Post by RESET_9999 » Fri Apr 22, 2022 2:45 pm
No you cant convert P7/P8 to P5 yet.
If you want the best quality , you need a device capable of playing dual layer DV like the X700 / X800m2 / OPPO
redoine322
#6404 Post by redoine322 » Fri Apr 22, 2022 7:40 pm
got it i was able to get this result what do think about it ..... it noticeably less Brighter then P7 .
General
Complete name                            : C:\Users\HICHA\Desktop\first\BL_EL_RPU.ts
File size                                : 53.9 GiB
Duration                                 : 1 h 45 min
Overall bit rate                         : 73.0 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086
Codec ID                                 : 6
Bit rate                                 : 67.8 Mb/s
Bits/(Pixel*Frame)                       : 0.341
Stream size                              : 50.1 GiB (93%)
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : 135
Bit rate                                 : 1 536 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 1.13 GiB (2%)
#6405 Post by RESET_9999 » Fri Apr 22, 2022 7:57 pm
that is not how it works, you're just changing the container profile and not the actual RPU metadata profile.
As I said, you can't convert P8/P7 to P5.
