redoine322 wrote:
Fri Apr 22, 2022 1:55 pm
understood ... is there any deference between P5 and 8 ?
P5 use a more efficient colorspace
redoine322
Post by redoine322 »
RESET_9999 wrote:
Fri Apr 22, 2022 2:20 pm
is there any way we can get a P5 ? just wanna get the best out of My new Tv :lol: :lol:
redoine322 wrote:
Fri Apr 22, 2022 2:37 pm
No you cant convert P7/P8 to P5 yet.
If you want the best quality , you need a device capable of playing dual layer DV like the X700 / X800m2 / OPPO
redoine322
RESET_9999 wrote:
Fri Apr 22, 2022 2:45 pm
got it i was able to get this result what do think about it ..... it noticeably less Brighter then P7 .
General
Complete name                            : C:\Users\HICHA\Desktop\first\BL_EL_RPU.ts
File size                                : 53.9 GiB
Duration                                 : 1 h 45 min
Overall bit rate                         : 73.0 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086
Codec ID                                 : 6
Bit rate                                 : 67.8 Mb/s
Bits/(Pixel*Frame)                       : 0.341
Stream size                              : 50.1 GiB (93%)
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : 135
Bit rate                                 : 1 536 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 1.13 GiB (2%)
that is not how it works, you're just changing the container profile and not the actual RPU metadata profile.
As I said, you can't convert P8/P7 to P5.
redoine322
RESET_9999 wrote:
Fri Apr 22, 2022 7:57 pm
Alright ..yeah the different in brightness caused by Plex Thanks RESET_9999 :D
Godmax
Post by Godmax »
So what happens if we get a Dolby Vision m2ts with cropped out black bars and they become grey on an Oppo 203 for example. Any way to fix this with tsmuxer or makemkv or sth?
ArArdin
Post by ArArdin »
redoine322 wrote:
Fri Apr 22, 2022 7:40 pm
Video
Very weird to see P5 with an enhancement layer.
stn17
Post by stn17 »
Heyo, seeing C9 owners use p7 FEL in .m2ts container instead of .mp4
Any reason for it?
I already have my algorithm perfected:
Rip BL, EL_RPU, THD, .mov Subtitles
eac3to to delete THD atmos extension if they are present
THD to eac3 with channel remapping
if DTSHDMA instead of THD, then straight into the ffmpeg to 1536k eac3 5.1
subtitles into SubtitleEdit to turn it into .srt
BL + EL + EC3 go into mp4muxer, .srt file next to it with .eng added for plex to recognize it
Any reason to use other tools? whats the upside/downside?
Mattl0
Post by Mattl0 »
Anyone tried the 5.0 fw from Ugoos on am6 b? Wonder how’s the dv playback. I will test it when I have time (currently the unit is somewhere, need to find it lol) .
D34DL1N3R
Post by D34DL1N3R »
Want to convert DV mkv profile 5 to MP4 using DoVi Scripts 1.2.1+tools.
I choose:
8) MODE.M4= MP4_muxer(p5/P8/P7)
and then
3) MODE.3= Demuxer (p5, p8, p7)
However, 3) asks for an mp4 file to demux instead of an mkv. If I try with the mkv I get this error:
Stream map '0:2' matches no streams.
To ignore this, add a trailing '?' to the map.
Is it possible to fix or someone to make a DOVi Tools script to demux mkv to create dv mp4?
mattmarsden
Post by mattmarsden »
Mattl0 wrote:
Sat Apr 23, 2022 5:04 pm
F9220A1F-B95D-4B07-83FB-19CFD5159257.pngC8E9B873-8502-4BDF-B4FD-3602ACEBADDC.pngA594274E-B3FB-4A57-91F1-051FBD0A3621.jpeg
Do you know where I can download the firmware from?
D34DL1N3R wrote:
Sun Apr 24, 2022 12:03 am
yes the demuxer in the mp4 mode is just for mp4 files.
You can demux your mkv with mkvextract and then use Mode.M4 --- > MODE.1 ---> Workflow.1
https://sourceforge.net/projects/gmkvextractgui/
knuffi123
Post by knuffi123 »
Can you please explain this a bit further so I understand the background. So when I take DV m2ts file from a UHD BD and convert it to a MKV with MKVtoolnix, then merge the dual layer DV tonsingle layer with makeMKV, what do I get as a result? Is that a faulty profile 5 with incorrect color space?
Thank you!
knuffi123 wrote:
Tue Apr 26, 2022 11:35 am
you get a lossless single-track dual-layer profile 7 files.
look at the end of this excel sheet, all the profiles are explained:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
