Will this enclosure work with LG BU40N?
Broly45
Post by Broly45 » Fri Apr 22, 2022 2:15 pm
Hi, I ordered a LG BU40N for my desktop pc and I wanted to use it with an enclosure however I live in Europe and ordering the Vantec enclosure everyone is recommending is difficult. I found this however and it seems to be appropriate.
https://www.delock.com/produkt/42604/merkmale.html
Now it says that it is for Slim drives not Ultra Slim which the BU40N is. Is that gonna be a problem? Should I look for something else? I know there is an Ultra Slim version I think the 42603 but I didn't find it anyware in my area. So will it be compatible despite it being for slim and not ultra slim? Thanks!
Re: Will this enclosure work with LG BU40N?
Post by Billycar11 » Fri Apr 22, 2022 2:30 pm
No looks like the slot is molded into the case order the vantec from Asmcom he's the European distributor see the guide for a link to him
Broly45
Post by Broly45 » Fri Apr 22, 2022 2:48 pm
Ok thanks I will look into that.
