Beta Key not working. MAKEMKV still says free period expired
Kyioto
Post by Kyioto »
I am using MAKEMKV 1.16.7 and the new Beta key viewtopic.php?f=5&t=1053
5/31/2022 does not seem to be working. when entered it says time limited
and license expiration 1.06.2022 not sure if this is MM/DD or DD/MM format.
when I go to open a disc I get the error that my evaluation period even though
the beta key should still allow it work through the end of May. I was wondering
what else needs to be done to get the free beta key to work
Kyioto
Re: Beta Key not working. MAKEMKV still says free period expired
Post by Kyioto »
anyone have any ideas? Posted this since it isn't covered in the Beta Key FAQ
Did you restart MakeMKV after adding the revised key?
Kyioto
Post by Kyioto »
Yes I have even restarted the computer and the error still existed. I was only able to get it to work after adjusting the computer date
The key is DDMM (day/month) order, so 01-06-2022 should be June 1, 2022. If you have set the computer date back to prior to 3/30/2022, it's reading the key wrong (or not picking it up).
