Cant converte iso. from harddrive?
magfei
#1 Post by magfei » Tue Mar 15, 2011 11:56 am
Hi all.
A new guy from Sweden here. My english might be a little odd sometimes. ;)
Well, i?m trying to converte an .iso that is on my hardrive. It worked som time ago, but now i just get a message that say that "not disc inserted". But it did work before to take an iso from my harddrive, and converte it into MKV which i then put in a folder also on my harddrive. Have been looking in preferenses, but cant find any settings to make it work.
What shall i do?
What settings must i adjust?
Why did it work before, but not now?
Its MakeMKV Beta.
Would be grateful for all help from you guys. :)
magfei
Re: Cant converte iso. from harddrive?
#2 Post by magfei » Wed Mar 16, 2011 9:29 am
Hi again.
I?m also get this message when im trying to cenverte:
"Using direct disc access mode
Failed to open disc"
Would be grateful to get some help so i can converte .iso to .mkv. I use seervio mediaplayer to watch movies throug my Samsung BD, and it doesnt take .iso.
setarip_old
#3 Post by setarip_old » Wed Mar 16, 2011 5:14 pm
Hi!
1) What is the original source material from which you created the .ISO image file?
2) What software and procedures did you use to create the .ISO image file?
magfei
#4 Post by magfei » Wed Mar 16, 2011 5:41 pm
Hi.
Thanx for your answer. :)
The .iso is created from a bunch of rar-files which is from a DVD.
And i have used Winrar to unpack it. Just click on the first rar-file and then extract them.
setarip_old
#5 Post by setarip_old » Thu Mar 17, 2011 3:00 am
In order to properly use MakeMKV to create an .MKV, simply load the ORIGINAL, COMMERCIAL DVD (NOT the .ISO image file) into makeMKV...
