#6361 Post by RESET_9999 » Fri Apr 15, 2022 4:11 pm
ArArdin wrote: Fri Apr 15, 2022 11:59 am Wondering if that would work. I have never tried to remux 7.1 EAC3 from a blu-ray to mkv or mp4. Would the different build-up be accepted by either container?
I just tried and it works in all the containers ( mp4 / mkv / ts) ... mkvtoolnix even keep the core intact (unlike the TrueHD tracks)
I didnt try to play the file but i expect it to work.
Complete name                            : D:\00000_P8_P8_DoVi.sub.au.mp4
Format                                   : mp43
Codec ID                                 : mp43 (isom/mp43/dby1)
File size                                : 4.83 GiB
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 10 min 0 s
Bit rate                                 : 68.3 Mb/s
Bits/(Pixel*Frame)                       : 0.343
Stream size                              : 4.77 GiB (99%)
Encoded date                             : UTC 2022-04-15 16:08:42
Tagged date                              : UTC 2022-04-15 16:09:04
Maximum Frame-Average Light Level        : 407 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format profile                           : Blu-ray Disc
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Stream size                              : 55.0 MiB (1%)
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 9 min 51 s
Bit rate                                 : 44 b/s
Stream size                              : 3.18 KiB (0%)
Title                                    : Grinch.2018.2160p.BluRay.REMUX
Encoded date                             : UTC 2022-04-15 16:09:04
redoine322
#6362 Post by redoine322 » Sat Apr 16, 2022 2:26 am
RESET_9999 wrote: Fri Apr 15, 2022 4:11 pm
Format                                   : mp43
Audio
Format                                   : E-AC-3
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 44 b/s
Could you plz explain to Me how to get an mp4 or mkv file to work on my LG C1 with DV please using your script From BDMV thanks for your hard Work Sir
ArArdin
#6363 Post by ArArdin » Sat Apr 16, 2022 4:46 am
RESET_9999 wrote: Fri Apr 15, 2022 4:11 pmI just tried and it works in all the containers ( mp4 / mkv / ts) ... mkvtoolnix even keep the core intact (unlike the TrueHD tracks)
Nice going, RESET_9999.
MKVToolnix indeed seems to keep "real core" audiostreams intact. Just like it does with DTS-HD. Good to know it works.
moobot
#6364 Post by moobot » Sat Apr 16, 2022 10:13 am
mtotheb wrote: Thu Jan 27, 2022 12:24 pm Has anybody tried the new https://www.mi.com/global/product/xiaomi-tv-stick-4k/
it seems to officially support HD Audio (DTS HD) as well as Dolby Vision. When I receive mine i’ll test if FEL playbacks correctly while also having HD Audio Passthrough.
Have you tested the Xiaomi 4k stick with DV yet, any good results?
#6365 Post by RESET_9999 » Sat Apr 16, 2022 1:13 pm
redoine322 wrote: Sat Apr 16, 2022 2:26 am Could you plz explain to Me how to get an mp4 or mkv file to work on my LG C1 with DV please using your script From BDMV thanks for your hard Work Sir
Theres tutorial video in my scripts link. check out the bluray to profile 8.1 one.
MODE.P7 ----> MODE.1 ----> Workflow.1
then use tsmuxer nightly to mux the output file with audio. you can edit the bat file with notepad so tsmuxer popup at the end of the process
just make sure there is no pgs sub or lossless audio pre-selected at playback. You can use external SRT subs
You can also use the mp4_muxer mode but it will take much longer time to process and some files may stutter on your C1
MODE.M4 ----> MODE.1 ----> Workflow.3
redoine322
#6366 Post by redoine322 » Sat Apr 16, 2022 2:54 pm
RESET_9999 wrote: Sat Apr 16, 2022 1:13 pm
Thank you for the Reply i did Try that but i got an error here is an Img ( there is plenty of space)
#6367 Post by RESET_9999 » Sat Apr 16, 2022 10:05 pm
redoine322 wrote: Sat Apr 16, 2022 2:54 pm i did Try that but i got an error here is an Img ( there is plenty of space)
yeah DGdemux wont work if you place the folder on your C:\ drive... do you have another drive you can put the folder on?
redoine322
#6368 Post by redoine322 » Sat Apr 16, 2022 10:24 pm
RESET_9999 wrote: Sat Apr 16, 2022 10:05 pm
Same Problem i did try it on two different drives
#6369 Post by RESET_9999 » Sat Apr 16, 2022 10:28 pm
redoine322 wrote: Sat Apr 16, 2022 10:24 pm
try 1.2.1, it should work.
https://drive.google.com/drive/u/0/fold ... L2KFZWTqKr
redoine322
#6370 Post by redoine322 » Sun Apr 17, 2022 1:15 am
RESET_9999 wrote: Sat Apr 16, 2022 10:28 pm
thank you So much it working Great Now here is the result the Dv is triggered but No audio on the Tv it says "this video does not support audio" .
General
File size                                : 55.6 GiB
Duration                                 : 2 h 23 min
Overall bit rate                         : 55.5 Mb/s
Video
Bit rate                                 : 51.2 Mb/s
Bits/(Pixel*Frame)                       : 0.258
Stream size                              : 51.3 GiB (92%)
Maximum Content Light Level              : 1506 cd/m2
Maximum Frame-Average Light Level        : 459 cd/m2
Audio
Format                                   : E-AC-3
Codec ID                                 : 132
Bit rate                                 : 1 536 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 1.54 GiB (3%)
viktrcoim
#6371 Post by viktrcoim » Mon Apr 18, 2022 3:30 am
Hi guys, Im kinda new to all this so here it goes:
I have some 4K files in p07 that I would love to convert to p8.1 or p5. I saw several messages here but Im kinda lost with this coding and muxes. I was able to instal ffmpeg in my mac (m1) but now i dont know what to do to convert a file. do i need to install anything else? Is there a tutorial for this?
#6372 Post by RESET_9999 » Mon Apr 18, 2022 9:54 pm
I took a look at the Dolby Vision metadata of The Batman itunes/movies anywhere/HBO and the differences are quite surprising. Itunes RPU is much larger even without L5 and L4. @Quietvoid, any idea why?
Also, why the hell are they all using the old Dolby vision algorithm CMV2.9... CMV4.0 is supposed to be superior, especially for the SDR trim passes. They can do the grade in 4.0 and then export in 2.9 for compatibility reasons though. Another interesting fact about HBO and MA, the colors are not the same(at least for HDR10) but they have the same L1/L2 DV metadata. https://slow.pics/c/axsHELui
The scene around frame 10625
iTunes:
- missing L5
- No L4
- No L6 maxcll/fall
- RPU is considerably larger than the other two
- no full range flag in the HEVC encode
    "cmv29_metadata": {
      "num_ext_blocks": 5,
      "ext_metadata_blocks": [
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "target_max_pq": 2081,
            "trim_slope": 650,
            "trim_offset": 2052,
            "trim_power": 1227,
            "trim_chroma_weight": 2048,
            "trim_saturation_gain": 2048,
            "ms_weight": 2048
          "Level2": {
            "target_max_pq": 2851,
            "trim_slope": 1787,
            "trim_offset": 2071,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "target_max_pq": 3079,
            "trim_slope": 2048,
            "trim_offset": 2049,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level6": {
            "max_content_light_level": 0,
            "max_frame_average_light_level": 0
MA :
- incorrect L5
- L4 present
- No L6 maxcll/fall
    "cmv29_metadata": {
      "num_ext_blocks": 7,
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "trim_slope": 650,
            "trim_power": 1227,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 1787,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 2048,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level4": {
            "anchor_pq": 220,
            "anchor_power": 180
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 0,
          "Level6": {
HBO:
- proper L5
- L4 present
- L6 complete
    "cmv29_metadata": {
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "trim_slope": 650,
            "trim_power": 1227,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 1787,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 2048,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level4": {
            "anchor_pq": 218,
            "anchor_power": 178
          "Level5": {
            "active_area_top_offset": 275,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 413,
            "max_frame_average_light_level": 65
#6373 Post by RESET_9999 » Tue Apr 19, 2022 12:08 am
mmmm Last night I watched half of the batman itunes DV WEB-DL and everything was fine.
Tonight I resumed the movie with the MA DV WEB-DL which as stated just above, has incorrect L5 metadata. It is set to 0 when it should be 276,276 (or 275,276 like hbo).
I noticed right away the black bars were not perfectly black like they were last night so I demuxed the rpu, edited L5 properly, injected it back, and voila, black bars are black again.
So this shows how important doing L5 properly is when doing the hybrid remux, especially if you play the movies on your TV internal player.
*** the raised black bars will only happen if a scene has L1 min_pq higher than 0.
*** My TV is in a projector room, so complete black velvet everywhere which makes this kind of issue easy to spot. I would probably never noticed that in a semi-bright room.
drew_nickel
#6374 Post by drew_nickel » Tue Apr 19, 2022 1:38 am
Hey whats up @RESET_9999
I've been lurking on here for a while now. I'm pretty much a novice to DV ripping/encoding stuff... With Yusesope's and your help I recently was successful in ripping my first DV movie (.m2ts file) file to DV profile 8 mp4. (So, that I can watch on my LG CX). Thanks!
Since then, Ive been examining a bunch different random DV movies and shows.
So, right before I saw this post, I myself noticed the different sizes of EL/RPU data. I've attached a screenshot of my file sizes. The 1st DV source that was leaked last night had an even larger sized EL/RPU data than the iTunes version. I'm not quite sure where that source came from though. You put down "iTunes, HBOmax, and MA" as the 3 sources you have. Forgive, my ignorance... but what source is "MA"?
Also, what do you make of HBOmax version being a few gigabytes larger in size? What do you make of that? Would that be the best version to watch?
I've attached a screenshot to show you what I got.
If anything that I'm saying is wrong or sound funny please dont hesitate to correct me :D
quietvoid
#6375 Post by quietvoid » Tue Apr 19, 2022 2:34 am
RESET_9999 wrote: Mon Apr 18, 2022 9:54 pmItunes RPU is much larger even without L5 and L4. @Quietvoid, any idea why?
Don't know, the info you included is only part of the metadata.
