Guide to flash new LG WH16NS60?
boolian2
#1 Post by boolian2 » Wed Apr 06, 2022 3:17 pm
I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
Re: Guide to flash new LG WH16NS60?
#2 Post by Billycar11 » Wed Apr 06, 2022 10:43 pm
boolian2 wrote: Wed Apr 06, 2022 3:17 pm I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
Link below
boolian2
#3 Post by boolian2 » Thu Apr 07, 2022 6:03 am
Billycar11 wrote: Wed Apr 06, 2022 10:43 pm
Link below
Does the LG Flasher flash both the correct firmware and LibreDrive? Or is LibreDrive THE firmware?
#4 Post by Billycar11 » Thu Apr 07, 2022 6:10 am
boolian2 wrote: Thu Apr 07, 2022 6:03 am
Link below
Flashing the firmware will enable libredrive
boolian2
#5 Post by boolian2 » Mon Apr 18, 2022 3:00 am
Billycar11 wrote: Thu Apr 07, 2022 6:10 am
Link below
I just flashed it with 1.02, it said operation successful. But in MakeMKV it still says the drive is 1.03.
EDIT: I was using command line before (unencrypted firmware command), I just used "SDF" GUI tool (said encrypted firmware) and MakeMKV now says 1.02. But what does "microcode access re-enabled" mean? Also, does 1.02 have the drive sleep bug? My old WH16NS60 is 1.00, should I also flash new drive with 1.00 instead of 1.02?
I used the 5.25 Desktop LG firmware from the "all you need" firmware pack on Google Drive link on your thread.
#6 Post by Billycar11 » Mon Apr 18, 2022 5:05 am
boolian2 wrote: Mon Apr 18, 2022 3:00 am
Both are fine go to 1.00 if you use other rippers that are not makemkv or anydvd
boolian2
#7 Post by boolian2 » Mon Apr 18, 2022 11:00 pm
Billycar11 wrote: Mon Apr 18, 2022 5:05 am
What about DVDFab? Does 1.02 work with it
#8 Post by Billycar11 » Mon Apr 18, 2022 11:38 pm
boolian2 wrote: Mon Apr 18, 2022 11:00 pm
boolian2
#9 Post by boolian2 » Tue Apr 19, 2022 2:27 am
Billycar11 wrote: Mon Apr 18, 2022 11:38 pm
You're correct, 1.02 doesn't work with DVDFab. I just tried it. I will downgrade to 1.00.
Phoenix0870
#10 Post by Phoenix0870 » Sat Sep 28, 2024 6:35 am
Hello.
LG WH16NS60 V1.00 is compatble all ripprograms, ok.
Which version is better in reading and writing?
(LG WH16NS60: V1.03/V1.02/V1.01/V1.00)
Is V1.03 faster than V1.02?
Is V1.02 faster than V1.01?
Is V1.01 faster than V1.00?
#11 Post by Billycar11 » Sat Sep 28, 2024 6:50 am
Phoenix0870 wrote: Sat Sep 28, 2024 6:35 am Hello.
all the same pretty much
