#6376 Post by RESET_9999 » Tue Apr 19, 2022 12:08 am
mmmm Last night I watched half of the batman itunes DV WEB-DL and everything was fine.
Tonight I resumed the movie with the MA DV WEB-DL which as stated just above, has incorrect L5 metadata. It is set to 0 when it should be 276,276 (or 275,276 like hbo).
I noticed right away the black bars were not perfectly black like they were last night so I demuxed the rpu, edited L5 properly, injected it back, and voila, black bars are black again.
So this shows how important doing L5 properly is when doing the hybrid remux, especially if you play the movies on your TV internal player.
*** the raised black bars will only happen if a scene has L1 min_pq higher than 0.
*** My TV is in a projector room, so complete black velvet everywhere which makes this kind of issue easy to spot. I would probably never noticed that in a semi-bright room.
drew_nickel
#6377 Post by drew_nickel » Tue Apr 19, 2022 1:38 am
Hey whats up @RESET_9999
I've been lurking on here for a while now. I'm pretty much a novice to DV ripping/encoding stuff... With Yusesope's and your help I recently was successful in ripping my first DV movie (.m2ts file) file to DV profile 8 mp4. (So, that I can watch on my LG CX). Thanks!
Since then, Ive been examining a bunch different random DV movies and shows.
So, right before I saw this post, I myself noticed the different sizes of EL/RPU data. I've attached a screenshot of my file sizes. The 1st DV source that was leaked last night had an even larger sized EL/RPU data than the iTunes version. I'm not quite sure where that source came from though. You put down "iTunes, HBOmax, and MA" as the 3 sources you have. Forgive, my ignorance... but what source is "MA"?
Also, what do you make of HBOmax version being a few gigabytes larger in size? What do you make of that? Would that be the best version to watch?
I've attached a screenshot to show you what I got.
If anything that I'm saying is wrong or sound funny please dont hesitate to correct me :D
quietvoid
#6378 Post by quietvoid » Tue Apr 19, 2022 2:34 am
RESET_9999 wrote: Mon Apr 18, 2022 9:54 pmItunes RPU is much larger even without L5 and L4. @Quietvoid, any idea why?
Don't know, the info you included is only part of the metadata.
ArArdin
#6379 Post by ArArdin » Tue Apr 19, 2022 9:29 am
RESET_9999 wrote: Tue Apr 19, 2022 12:08 amTonight I resumed the movie with the MA DV WEB-DL which as stated just above, has incorrect L5 metadata. It is set to 0 when it should be 276,276 (or 275,276 like hbo).
I haven't the Dolby Vision versions (yet), but the Batman films show different aspect ratios in one movie.
I understand setting L5 to 276 would be beneficial to the black bars. But wouldn't it also negatively affect DV playback on where normally the black bars would be, so when video is full frame?
Or is L5 also dynamic, and be adjustable for every scene/frame? If so, forgive my ignorance. I haven't done other with L5 than setting it to zero a couple of times.
#6380 Post by RESET_9999 » Tue Apr 19, 2022 11:02 am
ArArdin wrote: Tue Apr 19, 2022 9:29 am Or is L5 also dynamic, and be adjustable for every scene/frame? If so, forgive my ignorance. I haven't done other with L5 than setting it to zero a couple of times.
yes L5 is dynamic.
chros
#6381 Post by chros » Tue Apr 19, 2022 11:24 am
Nice summary, thanks! I took a quick look at hmax version, but I wasn't blown away by the image quality :)
quietvoid
#6382 Post by quietvoid » Tue Apr 19, 2022 2:18 pm
The iTunes stream has extra chroma reshaping, which makes reds slightly brighter.
https://slow.pics/c/Oa5JZnp6
So the reshaping params take a lot more bytes:
"num_pivots_minus_2": [
      7,
      3,
      3
#6383 Post by RESET_9999 » Tue Apr 19, 2022 2:22 pm
interesting. thanks
but are you sure this is what's causing the difference in colors because I see kind of the same difference when I compare HDR10 MA with HDR10 HBO. https://slow.pics/c/axsHELui
MA looks closer to the SDR grade.
quietvoid
#6384 Post by quietvoid » Tue Apr 19, 2022 2:53 pm
RESET_9999 wrote: Tue Apr 19, 2022 2:22 pm interesting. thanks
I didn't check HDR10, only Dolby Vision profile 5 for iTunes and HBO Max.
#6385 Post by RESET_9999 » Tue Apr 19, 2022 6:45 pm
quietvoid wrote: Tue Apr 19, 2022 2:53 pm I didn't check HDR10, only Dolby Vision profile 5 for iTunes and HBO Max.
yes, you're right. I've compared the 3 streaming services P5 web-dl tonemapped to SDR and on itunes, the red looks more orange/brighter. I prefer how it looks on MA and HBO... https://slow.pics/c/MrSz6BQ4
So iTunes does something different in their RPU( i wonder why) and it explains why we couldn't get a match with @manix Atomos Shogun appleTV samples here viewtopic.php?p=111073#p111073
The HDR10 color mismatch from MA and HBO is something else.
staknhalo
#6386 Post by staknhalo » Thu Apr 21, 2022 3:02 pm
RESET_9999 wrote: Tue Apr 19, 2022 6:45 pmSo iTunes does something different in their RPU( i wonder why)
I'd guess just 'artistic intent' for whoever authored the DV grade for iTunes encode
Just like they're responsible for their own encode/bitrate level output from what they receive from the studios, places just do what they want with the DV grading too so to speak I suppose
#6387 Post by RESET_9999 » Thu Apr 21, 2022 3:29 pm
staknhalo wrote: Thu Apr 21, 2022 3:02 pm I'd guess just 'artistic intent' for whoever authored the DV grade for iTunes encode
Would be true if only this movie had this special re-shapping but its not case, they do that for all the appleTV content as shown here viewtopic.php?p=111073#p111073
Also, a while ago, the ATV4k(itunes) used to tone map DV to HDR10 instead of streaming the HDR10 encode and I always wondered why the red always looked more orange than the other sources. Now i know why.
staknhalo
#6388 Post by staknhalo » Thu Apr 21, 2022 6:02 pm
RESET_9999 wrote: Thu Apr 21, 2022 3:29 pm
is it just 'artistic intent' across all apple stuff by whoevers authoring it there, title by title; or is it the same exact red push only, same exact metadata values each time, across all their content?
#6389 Post by RESET_9999 » Thu Apr 21, 2022 6:10 pm
staknhalo wrote: Thu Apr 21, 2022 6:02 pm is it just 'artistic intent' across all apple stuff by whoevers authoring it there, title by title; or is it the same exact red push only, same exact metadata values each time, across all their content?
I didnt check the metadata but yes it is the same red shift on every movie/show. That's why I don't see it as an artistic intent.
But I'll take a look at the metadata now that @quietvoid pointed out where to look.
quietvoid
#6390 Post by quietvoid » Thu Apr 21, 2022 6:59 pm
Yes, it looks static for all Apple TV content I've tested.
Usually the pivots are 7, 3, 3 (or really 9, 5, 5), and the value for chroma components is always 0, 288, 224, 224, 287 (pred_pivot_value).
The coefficients for all components also appears to be the same all the time, so Apple might just be doing a static reshape for all their content.
This is also why the non decoded image looks very different to other services.
