quietvoid
Post by quietvoid » Fri Apr 15, 2022 1:31 pm
ArArdin wrote: Fri Apr 15, 2022 11:59 am
nekno wrote: Fri Apr 15, 2022 6:19 am...but in my experience, applying a P5 RPU to an HDR10 BL does not yield the same results as a P7 RPU generated for an HDR10 BL in the DV mastering process.
I absolutely agree. In my early days of cross-injecting RPU, I've experienced significant differences between some HDR10 baselayers with P5 RPU and their native P7 RPU. I wonder if it's because of the different colorspace, or that P5 DV videos are a totally different DV grade because of whatever streaming-service reasons.
Anyone using the metadata from profile 5 files to "hybrid" should be comparing the PQ image to the regular profile 7 HDR10 version.
And in the case of FEL, the HDR10 image should be processed.
If they differ significantly, then the grade is different.
If not, then only the metadata can be different.
But that shouldn't be happening, since Dolby Vision is streamlined with a single source of metadata after grading.
Comparing HDR10 to Dolby Vision is pointless, and so is comparing profile 5 with unprocessed profile 7 FEL.
However it's possible that profile 5 streaming videos are enhanced in comparison to profile 7 MEL, since those are mapped down to a specific brightness.
That still would be caught by comparing the PQ grade.
FubbAyH
Post by FubbAyH » Fri Apr 15, 2022 3:00 pm
daylightcreative wrote: Fri Apr 15, 2022 9:30 am I have been scanning through this thread and find it fascinating and rather insightful. I've pulled down a few "HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU" hybrid releases only to find they don't play in my setup.
"dvhe.07.06" means that it's Dolby Vision Profile 7, which is the format used on discs. So those are probably just rips of discs that have Dolby Vision and not what we call hybrids here. What we call hybrids are rips where the HDR10 video is taken from a disc, and then the DV is added from another source (usually a Web-DL), and those are usually (maybe always?) distributed as Dolby Vision Profile 8 files.
daylightcreative wrote: Fri Apr 15, 2022 9:30 am All three have an NVIDIA Shield Pro 2019 connected to them
Looking at @RESET_9999's awesome DV playback device summary spreadsheet, I see that the Shield Pro does partially support Profile 7 rips, but they have to be "single-track dual-layer", and yours are presumably "dual-track dual-layer". So you can convert them, but I'm not sure what the right tool for that is. The downsides of the Shield Pro are that it doesn't support FEL (the "Full Enhancement Layer" extra video data which is found on some DV discs and is of debatable importance), and it has some long-standing color inaccuracy issues when playing Dolby Vision.
ArArdin
Post by ArArdin » Fri Apr 15, 2022 3:58 pm
quietvoid wrote: Fri Apr 15, 2022 1:31 pmComparing HDR10 to Dolby Vision is pointless, and so is comparing profile 5 with unprocessed profile 7 FEL.
Of course. In my post I was talking about comparing "Dolby Vision enabled playback" views.
When comparing P5 vs P7 RPU appliance, obviously using the baselayer of a native MEL title would yield the most transparent views.
Post by RESET_9999 » Fri Apr 15, 2022 4:11 pm
ArArdin wrote: Fri Apr 15, 2022 11:59 am Wondering if that would work. I have never tried to remux 7.1 EAC3 from a blu-ray to mkv or mp4. Would the different build-up be accepted by either container?
I just tried and it works in all the containers ( mp4 / mkv / ts) ... mkvtoolnix even keep the core intact (unlike the TrueHD tracks)
I didnt try to play the file but i expect it to work.
Complete name                            : D:\00000_P8_P8_DoVi.sub.au.mp4
Format                                   : mp43
Codec ID                                 : mp43 (isom/mp43/dby1)
File size                                : 4.83 GiB
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 10 min 0 s
Bit rate                                 : 68.3 Mb/s
Bits/(Pixel*Frame)                       : 0.343
Stream size                              : 4.77 GiB (99%)
Encoded date                             : UTC 2022-04-15 16:08:42
Tagged date                              : UTC 2022-04-15 16:09:04
Maximum Frame-Average Light Level        : 407 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format profile                           : Blu-ray Disc
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Stream size                              : 55.0 MiB (1%)
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 9 min 51 s
Bit rate                                 : 44 b/s
Stream size                              : 3.18 KiB (0%)
Title                                    : Grinch.2018.2160p.BluRay.REMUX
Encoded date                             : UTC 2022-04-15 16:09:04
redoine322
Post by redoine322 » Sat Apr 16, 2022 2:26 am
RESET_9999 wrote: Fri Apr 15, 2022 4:11 pm
Format                                   : mp43
Audio
Format                                   : E-AC-3
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 44 b/s
Could you plz explain to Me how to get an mp4 or mkv file to work on my LG C1 with DV please using your script From BDMV thanks for your hard Work Sir
ArArdin
Post by ArArdin » Sat Apr 16, 2022 4:46 am
RESET_9999 wrote: Fri Apr 15, 2022 4:11 pmI just tried and it works in all the containers ( mp4 / mkv / ts) ... mkvtoolnix even keep the core intact (unlike the TrueHD tracks)
Nice going, RESET_9999.
MKVToolnix indeed seems to keep "real core" audiostreams intact. Just like it does with DTS-HD. Good to know it works.
moobot
Post by moobot » Sat Apr 16, 2022 10:13 am
mtotheb wrote: Thu Jan 27, 2022 12:24 pm Has anybody tried the new https://www.mi.com/global/product/xiaomi-tv-stick-4k/
it seems to officially support HD Audio (DTS HD) as well as Dolby Vision. When I receive mine i’ll test if FEL playbacks correctly while also having HD Audio Passthrough.
Have you tested the Xiaomi 4k stick with DV yet, any good results?
Post by RESET_9999 » Sat Apr 16, 2022 1:13 pm
redoine322 wrote: Sat Apr 16, 2022 2:26 am Could you plz explain to Me how to get an mp4 or mkv file to work on my LG C1 with DV please using your script From BDMV thanks for your hard Work Sir
Theres tutorial video in my scripts link. check out the bluray to profile 8.1 one.
MODE.P7 ----> MODE.1 ----> Workflow.1
then use tsmuxer nightly to mux the output file with audio. you can edit the bat file with notepad so tsmuxer popup at the end of the process
just make sure there is no pgs sub or lossless audio pre-selected at playback. You can use external SRT subs
You can also use the mp4_muxer mode but it will take much longer time to process and some files may stutter on your C1
MODE.M4 ----> MODE.1 ----> Workflow.3
redoine322
Post by redoine322 » Sat Apr 16, 2022 2:54 pm
RESET_9999 wrote: Sat Apr 16, 2022 1:13 pm
Thank you for the Reply i did Try that but i got an error here is an Img ( there is plenty of space)
Post by RESET_9999 » Sat Apr 16, 2022 10:05 pm
redoine322 wrote: Sat Apr 16, 2022 2:54 pm i did Try that but i got an error here is an Img ( there is plenty of space)
yeah DGdemux wont work if you place the folder on your C:\ drive... do you have another drive you can put the folder on?
redoine322
Post by redoine322 » Sat Apr 16, 2022 10:24 pm
RESET_9999 wrote: Sat Apr 16, 2022 10:05 pm
Same Problem i did try it on two different drives
Post by RESET_9999 » Sat Apr 16, 2022 10:28 pm
redoine322 wrote: Sat Apr 16, 2022 10:24 pm
try 1.2.1, it should work.
https://drive.google.com/drive/u/0/fold ... L2KFZWTqKr
redoine322
Post by redoine322 » Sun Apr 17, 2022 1:15 am
RESET_9999 wrote: Sat Apr 16, 2022 10:28 pm
thank you So much it working Great Now here is the result the Dv is triggered but No audio on the Tv it says "this video does not support audio" .
General
File size                                : 55.6 GiB
Duration                                 : 2 h 23 min
Overall bit rate                         : 55.5 Mb/s
Video
Bit rate                                 : 51.2 Mb/s
Bits/(Pixel*Frame)                       : 0.258
Stream size                              : 51.3 GiB (92%)
Maximum Content Light Level              : 1506 cd/m2
Maximum Frame-Average Light Level        : 459 cd/m2
Audio
Format                                   : E-AC-3
Codec ID                                 : 132
Bit rate                                 : 1 536 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 1.54 GiB (3%)
viktrcoim
Post by viktrcoim » Mon Apr 18, 2022 3:30 am
Hi guys, Im kinda new to all this so here it goes:
I have some 4K files in p07 that I would love to convert to p8.1 or p5. I saw several messages here but Im kinda lost with this coding and muxes. I was able to instal ffmpeg in my mac (m1) but now i dont know what to do to convert a file. do i need to install anything else? Is there a tutorial for this?
Post by RESET_9999 » Mon Apr 18, 2022 9:54 pm
I took a look at the Dolby Vision metadata of The Batman itunes/movies anywhere/HBO and the differences are quite surprising. Itunes RPU is much larger even without L5 and L4. @Quietvoid, any idea why?
Also, why the hell are they all using the old Dolby vision algorithm CMV2.9... CMV4.0 is supposed to be superior, especially for the SDR trim passes. They can do the grade in 4.0 and then export in 2.9 for compatibility reasons though. Another interesting fact about HBO and MA, the colors are not the same(at least for HDR10) but they have the same L1/L2 DV metadata. https://slow.pics/c/axsHELui
The scene around frame 10625
iTunes:
- missing L5
- No L4
- No L6 maxcll/fall
- RPU is considerably larger than the other two
- no full range flag in the HEVC encode
    "cmv29_metadata": {
      "num_ext_blocks": 5,
      "ext_metadata_blocks": [
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "target_max_pq": 2081,
            "trim_slope": 650,
            "trim_offset": 2052,
            "trim_power": 1227,
            "trim_chroma_weight": 2048,
            "trim_saturation_gain": 2048,
            "ms_weight": 2048
          "Level2": {
            "target_max_pq": 2851,
            "trim_slope": 1787,
            "trim_offset": 2071,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "target_max_pq": 3079,
            "trim_slope": 2048,
            "trim_offset": 2049,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level6": {
            "max_content_light_level": 0,
            "max_frame_average_light_level": 0
MA :
- incorrect L5
- L4 present
- No L6 maxcll/fall
    "cmv29_metadata": {
      "num_ext_blocks": 7,
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "trim_slope": 650,
            "trim_power": 1227,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 1787,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 2048,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level4": {
            "anchor_pq": 220,
            "anchor_power": 180
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 0,
          "Level6": {
HBO:
- proper L5
- L4 present
- L6 complete
    "cmv29_metadata": {
          "Level1": {
            "min_pq": 12,
            "max_pq": 2081,
            "avg_pq": 1229
          "Level2": {
            "trim_slope": 650,
            "trim_power": 1227,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 1787,
            "trim_power": 1955,
            "ms_weight": 2048
          "Level2": {
            "trim_slope": 2048,
            "trim_power": 2048,
            "ms_weight": 2048
          "Level4": {
            "anchor_pq": 218,
            "anchor_power": 178
          "Level5": {
            "active_area_top_offset": 275,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 413,
            "max_frame_average_light_level": 65
