Read Error
charnathan
Read Error
Post by charnathan » Sun Jun 20, 2021 4:10 am
I was taken to this read error page when performing a full UHD disc back-up:
http://www.makemkv.com/errors/read/
And the solution provided on this page says "there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details." (See last paragraph on this page)
BUT, it doesn't provide a link to the thread that explains what to do next. And I don't see any sticky thread that explains this either.
Can a mod please provide the exact steps to follow and update the error page to include a link to the solution in the forum?
audit13
Re: Read Error
Post by audit13 » Sun Jun 20, 2021 3:51 pm
There are usually two types of read errors:
1) the decryption key for the disc is unknown and you will need to submit a file dump; and
2) errors that are the result of a dirty or defective disc.
If you want to perform a full backup, use the option at the top of the program. You can choose to either make an encrypted backup if the key is unknown or decrypted backup if the key is known.
charnathan
Re: Read Error
Post by charnathan » Sun Jun 20, 2021 8:24 pm
I'm mainly trying to figure out what is the "fast and simple" way to convert copying the disc manually (via copy and paste from the disc to a folder on the desktop) so that I can compare if my original back-up is corrupted or not.
audit13
Re: Read Error
Post by audit13 » Mon Jun 21, 2021 3:22 pm
The easiest way to determine if the disc is or isn't readable is to create a decrypted back up if the key is know or an encrypted backup if the key is unknown.
Manually copying and pasting won't work for every file on the disc since the disc is encrypted.
What read errors are you getting?
sdavies2720
Re: Read Error
Post by sdavies2720 » Sat Apr 16, 2022 1:34 pm
I'm also hitting this. Following the instructions on the page (and not having "denial") I copied all of the files to my hard drive. Now I'm looking for the "fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details."
The error from makemkv was:
Failed to save title 1 to file D:/WorkArea//MARVEL'S IRON MAN 3 - BLU-RAY_t01.mkv
Encountered 95 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL ASUS DRW-24B1ST j 1.11 J8D0CL009982' at offset '1048576'
sdavies2720
Re: Read Error
Post by sdavies2720 » Sat Apr 16, 2022 1:47 pm
Looking a little further, I've found this thread:
viewtopic.php?f=12&t=17087&p=60530&hilit=discatt#p60530
I'm currently working through that and will post whether it worked.
sdavies2720
Re: Read Error
Post by sdavies2720 » Sat Apr 16, 2022 1:55 pm
Ok, no, that didn't solve the problem. Now I'm getting:
Failed to save title 4 to file D:/WorkArea//MARVEL'S IRON MAN 3 - BLU-RAY_t04.mkv
Encountered 258 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
That page indicates that I have a failing bluray drive...
Re: Read Error
Post by dcoke22 » Sat Apr 16, 2022 3:55 pm
HashCheck errors are often the result of the disc being dirty. Have you tried cleaning the disc? I like to use warm water and plenty of dish soap to gently clean the disc. After rinsing, I dry the disc using a can of air to blow off the water on the data side.
sdavies2720
Re: Read Error
Post by sdavies2720 » Sat Apr 16, 2022 5:45 pm
The Hashcheck errors came when I followed the instructions and copied the discatt.dat file to my copy directory, then ran MakeMKV from the hard disc directory.
The disc is relatively new and looks pristine. I went ahead and cleaned it anyway and tried to run MakeMKV against it again. Now I'm getting a slightly different error stream. Perhaps my drive IS going bad:
Saving 1 titles into directory D:/WorkArea/
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '23437178880'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '23437178880'
Re: Read Error
Post by dcoke22 » Sat Apr 16, 2022 9:41 pm
Are you getting errors when trying to use MakeMKV to read the optical disc to make a (presumably decrypted) backup?
Or are you getting errors when trying to read an ISO?
Bandito
Re: Read Error
Post by Bandito » Tue Aug 06, 2024 6:38 pm
i have also problems with a BRAND NEW FRESH OPEND UHD
here are the logs:
MakeMKV v1.17.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Stefa/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Backing up disc into folder "D:/Video/backup/UHD Iron Man 3"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00038.m2ts' at offset '217706496'
Failed to save title /BDMV/STREAM/00038.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00038.m2ts
DEBUG: Code 0 at J"Rq{dP<\@!2zM>ew:121267063
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00039.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00039.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00040.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00040.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00040.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00031.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00031.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00027.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00027.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00011.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00011.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00017.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00017.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00017.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00023.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00023.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00020.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00020.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00021.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00021.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00021.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00024.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00024.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00000.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00000.m2ts
Encountered 4 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 12 files failed hash check
Any Idea?
What i can check or make?
What is the DUMP File?
You need it?
How can i create it?
Iside the LOG File i have these Errors:
Debug log started at Tue Aug 06 18:21:09 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Stefa/MakeMKV_log.txt
No  SDF v098: HL-DT-ST_DVDRAM_GHC0N_WF01_201509011433_710HC009302
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF id v098: HL-DT-ST_DVDRAM_GHC0N_WF01_201509011433_710HC009302
SDF  v098: ASUS_BW-16D1HT_3.10_211901041014_KLQL6DB4551
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
005072:0000 Backing up disc into folder "file://D:/Video/backup/UHD Iron Man 3"
DEBUG: Code 2147483648 at vtE<(>?]*E!<z7r!:121265499
001003:0020 DEBUG: Code 3221225628 at wsuH-I{pjx"D{a*<>oxG0$',:121262371
001003:0020 DEBUG: Code 3221225628 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 100864261 at :_D~hKrDX!l7kzzP:121271617
001003:0020 DEBUG: Code 100864261 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 100860416 at :_D~hKrDX!l7kzzP:121271617
001003:0020 DEBUG: Code 100860416 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 101000192 at :_D~hKrDX!l7kzzP:121271617
001003:0020 DEBUG: Code 101000192 at y/G?z@b0R+~Y]$0V:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00038.m2ts' at offset '217706496'
005003:0000 Failed to save title /BDMV/STREAM/00038.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00038.m2ts
001003:0020 DEBUG: Code 3221225488 at wsuH-I{pjx"D{a*<>oxG0$',:121262371
001003:0020 DEBUG: Code 3221225488 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 0 at J"Rq{dP<\@!2zM>ew:121267063
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00039.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00039.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00040.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00040.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00040.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00031.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00031.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00031.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00027.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00027.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00011.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00011.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00017.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00017.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00017.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00023.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00023.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00020.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00020.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00021.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00021.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00021.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00024.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00024.m2ts
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00000.m2ts to file D:/Video/backup/UHD Iron Man 3/BDMV/STREAM/00000.m2ts
002023:0000 Encountered 4 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06030200 count=1 name=Scsi error - MEDIUM ERROR:NO SEEK COMPLETE
error=0x06031105 count=3 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 80 unclassified errors
error=0x06052400 count=79 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC000009C count=1 name=OS error - STATUS_DEVICE_DATA_ERROR
005079:0080 Backup done but 12 files failed hash check
005082:0404 Backup done but 12 files failed hash check.
Application exited at Tue Aug 06 18:36:29 2024
Re: Read Error
Post by SamuriHL » Tue Aug 06, 2024 7:19 pm
I love when people stress "brand new right out of the box" as though that means ANYTHING at all. The usual advice ALWAYS, every single time, applies. Clean the disc. If that doesn't work, try a different/better drive. Failing that, the disc is likely bad. This idea that discs coming right out of the package are somehow pristine and not subject to issues is complete and total nonsense. I've had FINGERPRINTS on "BRAND NEW" UHD's. Most of them have an oily substance on them from the manufacturing process these days. Stressing that it's "BRAND NEW" means NOTHING.
Bandito
Re: Read Error
Post by Bandito » Wed Aug 07, 2024 5:38 am
Ohh ok.
I thought that a new unpacked UHd was in perfect condition.
In other words, that there are no problems like dust or fingerprints.
I will try to clean it.
Thank you for your detailed description of the problems that can occur.
I thought it might be due to a new copy protection or maybe even that you got a disc that nobody has read before.
