MakeMKV appears to be doing a straight copy of bluray
golanhenry
Post by golanhenry » Wed Apr 13, 2022 10:11 pm
Hello recently I ran into system problems and had to rebuild my HP desktop from factory specs. I am running windows 10. When I re-installed MakeMKV and attempt to copy a disc it appears to copy the disc into 3 folders and 1 file
The 3 folders are
AACS
BDMV
CERTIFICATE
and the file is
discatt.dat
Normally the folders created by MakeMKV are
BDMV
CERTIFICATE
MAKEMKV
As it stands I can't rebuild or backup copy to another disc as I don't think the protection is being stripped. I have MAKEMKV installed on another laptop and it works fine there but at a much slower rate.
Re: MakeMKV appears to be doing a straight copy of bluray
Post by Billycar11 » Thu Apr 14, 2022 12:23 am
Make sure your checking the decrypt box
golanhenry
Post by golanhenry » Thu Apr 14, 2022 9:58 pm
Thanks for that. I never noticed it before. Spent several frustrating weeks trying to figure out what I did wrong.
