Windows 10 doesn't seem to detect my Asus BW-16D1HT drive
Franchiver
Greetings,
I'm trying to use a Asus BW-16D1HT optical disc drive with my Windows 10 laptop, by connecting it through an Unitek Y-1099-EU USB-to-SATA adapter. However, the drive keeps failing to appear in the File Explorer. In the Device Manager, it seems to appear as an "unknown USB device".
It can be opened and closed, though even inserting a Blu-Ray in it doesn't change anything.
Through Windows Update, I updated the ASUStek driver (not the firmware) to the latest version - to no avail.
Could I have missed something to make it work?
Any hint would be greatly appreciated!
Re: Windows 10 doesn't seem to detect my Asus BW-16D1HT drive
do you have the power adapter plugged in to the unitek?
Are you sure it's your optical drive showing as such, and not the adapter itself that maybe isn't properly installed?Franchiver wrote: ↑Tue Apr 12, 2022 9:02 pmIn the Device Manager, it seems to appear as an "unknown USB device".
Franchiver
Yes.Billycar11 wrote: ↑Wed Apr 13, 2022 12:31 amdo you have the power adapter plugged in to the unitek?
Not 100% positive, I'm afraid. By "properly installed", do you mean "properly plugged"? Or is there something I should have installed along with it?ArArdin wrote: ↑Wed Apr 13, 2022 10:28 amAre you sure it's your optical drive showing as such, and not the adapter itself that maybe isn't properly installed?Franchiver wrote: ↑Tue Apr 12, 2022 9:02 pmIn the Device Manager, it seems to appear as an "unknown USB device".
I don't believe that model adapter works with optical drives anymore.Franchiver wrote: ↑Tue Apr 12, 2022 9:02 pmGreetings,
Hmm I thought it only no longer works with flashing but then that was fixed I may have to take it off the list thenMartyMcNuts wrote: ↑Thu Apr 14, 2022 3:28 am
https://www.unitek-products.com/product ... 5-3-5-inchBillycar11 wrote: ↑Thu Apr 14, 2022 4:21 amHmm I thought it only no longer works with flashing but then that was fixed I may have to take it off the list thenMartyMcNuts wrote: ↑Thu Apr 14, 2022 3:28 am
It no longer mentions optical drives in the product description.
ok they are removed sorry if thats the reason you bought it
Franchiver
Thank you all. That's bad news indeed. I guess I should have read those specs from the manufacturer's website instead of the obviously misleading Amazon pageBillycar11 wrote: ↑Thu Apr 14, 2022 5:15 amok they are removed sorry if thats the reason you bought it
So, should I replace the adapter or the optical drive? Which models should I choose?
The adapter see the listed adapters in the guide that work with optical drivesFranchiver wrote: ↑Thu Apr 14, 2022 7:07 am
Thank you all. That's bad news indeed. I guess I should have read those specs from the manufacturer's website instead of the obviously misleading Amazon page![]()
Franchiver
Thank you all again. My new Alxum AX-SC021NEW seems to do the trick. Now, I guess I'm supposed to find how to flash it...
Linked below or buy an automated flasher from me or Marty we both sell themFranchiver wrote: ↑Tue Apr 26, 2022 12:32 pmThank you all. My new Alxum AX-SC021NEW seems to do the trick. Now, I guess I'm supposed to find how to flash it...
Franchiver
Thank you.Billycar11 wrote: ↑Tue Apr 26, 2022 12:36 pmLinked below or buy an automated flasher from me or Marty we both sell themFranchiver wrote: ↑Tue Apr 26, 2022 12:32 pmThank you all. My new Alxum AX-SC021NEW seems to do the trick. Now, I guess I'm supposed to find how to flash it...
