darrrkmanxxx
#6346 Post by darrrkmanxxx » Sun Apr 10, 2022 4:16 pm
Yoshitaka wrote:
Sun Apr 10, 2022 7:41 am
darrrkmanxxx wrote:
Fri Apr 08, 2022 6:56 am
Hey I have that too with p5 or p8 mp4. You can just drag and drop the file into mkvtoolnix and remux to mkv. It will play without stutters and the dolby vision will be kept. I usually playback those with just Player or vimu. Mkv work a lot better than mp4
TVs dont support DV MKVs.
Where do you get that from? You can easily play with Vimu apk or Just player. Dolby Vision and Atmos will be triggered, even the notification appears and there‘s a clearly difference to normal HDR
[/quote]
I am using an LG C9 and do not have an external player. The LG C9 as far as we all know, only plays mp4s ts and m2ts files that are DV.
[/quote]
I have Philips 65OLED934 from 2019 and can play dv mkv through plex or vimu without any external player.
#6347 Post by RESET_9999 » Sun Apr 10, 2022 4:20 pm
Yoshitaka wrote:
Sun Apr 10, 2022 7:36 am
Hmmm Which option would I select from your .bat going from bdmv, or even mkv dv that's already dv, to a dv format the lg c9 can handle?
from BDMV: Mode P7 (3) ---> Mode 1 (1) ---> Workflow 1 (1)
from MKV P7: Mode P7 (3) ---> Mode 2 (2) ---> Workflow 2 (2)
then tsmuxer nightly to mux the output files. There are also the same workflows in the mp4muxer modes.
good to know.
LG TVs dont support DV MKV
darrrkmanxxx
#6348 Post by darrrkmanxxx » Sun Apr 10, 2022 6:07 pm
good to know.
Ok, got you. Sorry for the misunderstanding.
dompidu
#6349 Post by dompidu » Mon Apr 11, 2022 3:27 pm
Hey, has anyone had any problems to get to play Spider-Man No Way Home DV P7 Framestor Remux in the Sony X700?
I converted the mkv to m2ts using latest nightly tsmuxer but the player freezes and shows a black screen, nothing ever plays.
Is there something I may be doing wrong? Thanks.
#6350 Post by RESET_9999 » Mon Apr 11, 2022 5:23 pm
Normal... all the MEL 2mbps movies muxed in ST-DL wont work on the x700/x800m2 ( some fel movie as well).
If you demux and remux to DT-DL, it will work. You can also convert it to profile 8 since its a mel movie, you wont lose any quality.
ArArdin
#6351 Post by ArArdin » Mon Apr 11, 2022 9:48 pm
all the MEL 2mbps movies muxed in...
Anybody knows if or what is wrong with titles that carry a 2mbps MEL? Figuring that MEL is just a placeholder for RPU, I wonder what other crap is stored within to make up for this high bitrate. I'm comparing to other titles with MEL going @ 60 - 90 kbps.
#6352 Post by RESET_9999 » Mon Apr 11, 2022 10:02 pm
I would like to know that as well... We should ask Stacey Spears since they used a 2mbps bitrate on the MEL version of their montage.
https://forum.blu-ray.com/showthread.ph ... 27&page=52
quietvoid
#6353 Post by quietvoid » Mon Apr 11, 2022 11:51 pm
As far as I know, the difference is how the EL stream is encoded.
2mbps is a regular encode of a static grey image, while the lowest bitrate ones are simply zeroed out, resulting in a green output when decoded.
You can simply look at the bitstream and see a bunch of zeros in slices.
Regardless of method, the final output should be the same.
mehgh750
#6354 Post by mehgh750 » Wed Apr 13, 2022 5:01 am
@ RESET_9999
Does Sony X800M2 play profile 8 MKV? I thought it couldn't play DV MKV at all.
#6355 Post by RESET_9999 » Wed Apr 13, 2022 4:25 pm
No, only TS/M2TS/MP4
dompidu
#6356 Post by dompidu » Wed Apr 13, 2022 5:29 pm
Thanks so much, got it working. Regarding your scripts, which would be the options/steps to follow?
#6357 Post by RESET_9999 » Wed Apr 13, 2022 6:22 pm
SL P8:
MODE.P7 ---> MODE.2 (p7 ST-DL to p8) ---> Workflow.4 (P7 ST-DL to P8)
or
DT-DL P7:
MODE.P7 ---> MODE.3 (p7 ST-DL to DT-DL) ---> Workflow.4 (P7 ST-DL to DT-DL)
Omni4
#6358 Post by Omni4 » Thu Apr 14, 2022 9:48 am
@RESET_9999
First of all: Thanks for all your hard work!!
I'm converting the Dolby Vision demos from Dolby UHD Blu-Ray Demo Disc (March 2018) with your DoVi Scripts. I play them with Kodi on my Sony TV via USB, works like a charm.
I have a bug report and a request:
When I use MP4_muxer(p5/P8/P7) > dual-track (p7) > MPLS P7 bluray to DT-DL + EAC3 ... only the 1080p track has Dolby Vision.
And the request: Can you add the option to extract and mux the DD+ 7.1 tracks in MPLS P7 bluray to P8 and MKV P7 to P8?
Cheers,
Omni4
#6359 Post by RESET_9999 » Thu Apr 14, 2022 2:11 pm
Hi, that is how dual-track dual-layer P7 DoVi works. The DV metadata/layer is stored in the 1080p stream and merged with the 2160p stream at playback.
DD+ 7.1 tracks are kind of rare, so I'm not sure I will ever add support for that.
Not ideal but you could just convert the bluray to P8, demux 7.1 audio with tsmuxer, and then build your P8 mp4 with 7.1 audio.
convert BD to P8 HEVC:
MODE.P7 ----> MODE.1 ----> Workflow.2
then build your P8 mp4 with 7.1 audio:
MODE.M4 ----> MODE.1 ----> Workflow.2
Omni4
#6360 Post by Omni4 » Thu Apr 14, 2022 4:59 pm
Thanks for the explanation and tip!
