failed DVD rip due to aggressive copy protection?
Garbald
#1 Post by Garbald » Wed Apr 13, 2022 5:19 pm
My copy of the German issue of "Fearless" (Constantin Film around 2007, distributed by Highlight, ImgBurn identifies the protection type as CSS/CPPM) refuses to get ripped with error messages I have not seen before. MakeMKV finds the main film but only part of it (~40 minutes are missing at the end). In the log below Title #2 is the main film which should run around 99 minutes. The disk works nicely in a DVD player and other DVDs rippped even today nicely with my MakeMKV so I guess we have extremely heavy handed DVD protection here. One other DVD shows the same problem (suspiciously also from Constantin Film distributed by Highlight around 2007 - "La vie en rose") otherwise I haven't seen this problem in any of my ~4000 DVDs. I tried to read the image from disk to rip from this later but this will take forever due to probably intentionally placed bad sectors. Do you have any tips what I could try?
Here the debug log:
Debug log started at Wed Apr 13 16:04:51 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\tietz.Elbereth/MakeMKV_log.txt
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF  v089: ASUS_BW-16D1HT_3.10_211901041014_KL4KBLE0642
001012:0000 udf: UDF: BROKEN DIRECTORY ENTRY
001003:0020 DEBUG: Code 0 at o_Xa1f//iCn}@`Kn-:121262164
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #4 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #5 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #6 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #7 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #8 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #9 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #10 does not match one in IFO header.
003024:1000 Complex multiplex encountered - 1 cells and 135 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
vobs=ZeNpzchoFo2AUjIJRMApGwUgDAIvPEB8=
001003:0020 DEBUG: Code 741 at _<^p}-OUaz*]Q!NA:121263383
001003:0020 DEBUG: Code 0 at xWCQ#r~7FJ6`0,x0:?:121272997
001003:0020 DEBUG: Code 0 at xWCQ#r~7FJ6`0,x0:?:213142726
003015:0000 Title #1 (0:01:10) was skipped due to navigation error
Title skip vts=1 pgcn=1 hash=A5B925582BA0C127
003024:1000 Complex multiplex encountered - 10 cells and 6196 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (10 cell(s), 0:53:37)
Title skip vts=1 pgcn=3 hash=5C2DAC68BA9D5124
003028:0000 Title #4 was added (1 cell(s), 0:00:04)
003028:0000 Title #5 was added (1 cell(s), 0:00:18)
003028:0000 Title #6 was added (1 cell(s), 0:00:05)
003024:1000 Complex multiplex encountered - 1 cells and 271 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #7 was added (1 cell(s), 0:02:21)
Title skip vts=2 pgcn=5 hash=F811BD909631F7A6
003028:0000 Title #9 was added (1 cell(s), 0:00:11)
003028:0000 Title #10 was added (1 cell(s), 0:00:20)
003024:1000 Complex multiplex encountered - 2 cells and 1855 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #11 was added (2 cell(s), 0:16:04)
003024:1000 Complex multiplex encountered - 1 cells and 924 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #12 was added (1 cell(s), 0:08:00)
003024:1000 Complex multiplex encountered - 3 cells and 297 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #13 was added (3 cell(s), 0:02:32)
003024:1000 Complex multiplex encountered - 3 cells and 201 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #14 was added (3 cell(s), 0:01:43)
003028:0000 Title #15 was added (1 cell(s), 0:00:37)
003024:1000 Complex multiplex encountered - 2 cells and 167 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #16 was added (2 cell(s), 0:01:26)
Title skip vts=7 pgcn=1 hash=C2344C7EEB75250A
003024:1000 Complex multiplex encountered - 1 cells and 245 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #18 was added (1 cell(s), 0:02:08)
003024:1000 Complex multiplex encountered - 1 cells and 203 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #19 was added (1 cell(s), 0:01:47)
003024:1000 Complex multiplex encountered - 1 cells and 274 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #20 was added (1 cell(s), 0:02:30)
003024:1000 Complex multiplex encountered - 1 cells and 222 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #21 was added (1 cell(s), 0:01:57)
003028:0000 Title #22 was added (1 cell(s), 0:00:16)
003024:1000 Complex multiplex encountered - 1 cells and 172 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #23 was added (1 cell(s), 0:01:30)
003028:0000 Title #24 was added (1 cell(s), 0:00:11)
003024:1000 Complex multiplex encountered - 1 cells and 272 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #25 was added (1 cell(s), 0:02:35)
Title skip vts=9 pgcn=1 hash=A06B819BF8C25328
Title skip vts=10 pgcn=1 hash=6599AAADC79FF58C
003034:0000 Audio stream #0 looks empty and was skipped
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 251904, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 319488, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 894976, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1015808, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1931264, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 2029568, attempting to work around
001003:0020 DEBUG: Code 0 at }z`C|XX7*XEY*pEBKa\:121264119
vobs=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
vobs=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
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 14336, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 20480, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 26624, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 30720, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 38912, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 43008, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 57344, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 75776, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 79872, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 86016, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 92160, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 106496, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 133120, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 212992, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 235520, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 514048, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 561152, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 641024, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 917504, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 968704, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 51200, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 77824, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 100352, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 129024, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 165888, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 192512, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 229376, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 253952, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 288768, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 315392, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 339968, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 364544, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 405504, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 438272, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 489472, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 524288, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 555008, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 579584, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 604160, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 645120, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 698368, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 724992, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 788480, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 819200, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 913408, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 937984, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 962560, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1001472, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1028096, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1054720, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1095680, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1122304, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1153024, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1177600, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1202176, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1243136, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1267712, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1300480, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1359872, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1386496, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1417216, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1441792, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1480704, attempting to work around
004004:0000 The source file 'BD-RE ASUS BW-16D1HT 3.10 KL4KBLE0642' is corrupt or invalid at offset 1544192, attempting to work around
001003:0020 DEBUG: Code 12 at X&zxjRzaaJ'g4R5,3?f,UT:213129915
005014:0000 Saving 1 titles into directory file:////mediabox/video/F/Fearless (2006)
002021:0000 Unable to open file '/VIDEO_TS/VTS_01_1.VOB' in OS mode due to a bug in OS Kernel. This can be worked around, but read speed may be very slow.
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
