Or are there host certificates floating arround I could use?
Accidentally Poisoned drive
I played a disc with AACS v76 and revoked the host certificates that are included in the public keydb.cfg (they are only valid till v72) is there some way to get valid host certificates for the other versions or am I screwed for now till the public one updates in who knows how many months/years/decades?
Re: Accidentally Poisoned drive
only way around it is libredrive if you have a compatible drive or to wait
Okay do you have a rough estimate how long I will have to wait till the new keys will be public? Oh and also how can I use libredrive outside of makemkv if thats even possible?Billycar11 wrote: ↑Wed Apr 13, 2022 12:34 amonly way around it is libredrive if you have a compatible drive or to wait
To use libredrive outside makemkv you open makemkv open the disc in makemkv then close makemkv.
I have never tried it for getting around the aacs problem but that's how it works to get around buss encryption
Ah okay thank you for your reply, somehow thought there was a standalone libredrive thing xDBillycar11 wrote: ↑Thu Apr 14, 2022 12:22 amTo use libredrive outside makemkv you open makemkv open the disc in makemkv then close makemkv.
@DirkAbt1 Just think of it as a special firmware. I'm still a little confused by it because I believe even once Libredrive you still need to download something from the Internet to open each movies (different keys??)
