ASUS BW-16D1HT
ASUS BW-16D1HT
Hello, I decided that I'm going to start using DVDfab for when I want to make ISO rips. but for some reason I keep getting this message when launching it. should I just ignore it? I never actually used my drive to rip 4k blu-rays. but it should be able to because it's a libredrive with a patched firmware that I bought a while ago. https://imgur.com/Sd2CXZR
Re: ASUS BW-16D1HT
The mk firmware does not work with dvdfab but does work with makemkv and anydvd.
Re: ASUS BW-16D1HT
Billy,Billycar11 wrote: Sun Apr 10, 2022 9:29 pm The mk firmware does not work with dvdfab but does work with makemkv and anydvd.
I would suggest that he crossflashes his drive to LG BH16NS60 1.00. This should work with all three softwares. Your opinion?
Re: ASUS BW-16D1HT
sure that or WH16NS60 1.00 that firmware is more readily available.Coopervid wrote: Sun Apr 10, 2022 10:00 pmBilly,Billycar11 wrote: Sun Apr 10, 2022 9:29 pm The mk firmware does not work with dvdfab but does work with makemkv and anydvd.
but they may then not be able to burn discs its rare but does happen
Great_Dane22
Re: ASUS BW-16D1HT
I use the same drive for making isos with dvdfab and i have no problems i think i had that message first time clicked ignore i mostly make 4k UHD isos and don't have any problems using 3.10 patched i love make mkv i use that for my plex serveriTM_Havok wrote: Sun Apr 10, 2022 9:22 pm Hello, I decided that I'm going to start using DVDfab for when I want to make ISO rips. but for some reason I keep getting this message when launching it. should I just ignore it? I never actually used my drive to rip 4k blu-rays. but it should be able to because it's a libredrive with a patched firmware that I bought a while ago. https://imgur.com/Sd2CXZR
i recommend to purchase make mkv to support mike and all his hard work.
you can use make mkv and imagburn to make a iso. but has some AACS protection on it then mount it and then make iso with dvdfab to remove remaing copy protection.
i use the make mkv and imgburn method to make iso of problem disc using pioneer drive.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Re: ASUS BW-16D1HT
Oh… the person that I bought the drive from recommended that I flash my drives firmware to 3.01. but I guess I don’t have to.Great_Dane22 wrote: Mon Apr 11, 2022 12:34 pmI use the same drive for making isos with dvdfab and i have no problems i think i had that message first time clicked ignore i mostly make 4k UHD isos and don't have any problems using 3.10 patched i love make mkv i use that for my plex serveriTM_Havok wrote: Sun Apr 10, 2022 9:22 pm Hello, I decided that I'm going to start using DVDfab for when I want to make ISO rips. but for some reason I keep getting this message when launching it. should I just ignore it? I never actually used my drive to rip 4k blu-rays. but it should be able to because it's a libredrive with a patched firmware that I bought a while ago. https://imgur.com/Sd2CXZR
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
What do you mean by problem discs? do some 4K blu-rays just not rip sometimes using DVDfab to make an ISO?
I Already own a copy of MakeMKV. so I could just make a BDMV backup if that ever happens to me.
Re: ASUS BW-16D1HT
whats the point of buy a drive from someone if it does not flashed to what you need it to be flashed toiTM_Havok wrote: Tue Apr 12, 2022 4:41 am
if you buy from me or marty or asmcom it would have come with the firmware you need
