Hell or High Water Volume Key Unknown
mattywoz87
#1 Post by mattywoz87 » Sun Apr 10, 2022 8:55 am
Trying to backup hell or high water uhd us disc. Got the message that the volume is unknown which i thought was strange since the disc was released in 2018. Sent the dump file to svq@makemkv.com on 4th April but still getting the same message.
Any ideas?
Re: Hell or High Water Volume Key Unknown
#2 Post by dcoke22 » Sun Apr 10, 2022 4:13 pm
Fixing Volume Key is Unknown
Try reading through that.
mattywoz87
#3 Post by mattywoz87 » Sun Apr 10, 2022 4:52 pm
Thanks, there nothing listed there that will help though unless the key has not been produced yet which i find hard to believe. I've backed up over 100 uhd discs without problems.
#4 Post by dcoke22 » Sun Apr 10, 2022 5:01 pm
Sometimes new pressings or different versions of the disc end up with different keys. In a quick search of this forum, I didn't find a post where someone mentioned they submitted a key originally, so I have no idea if your key, "0F3D", is new or not.
mattywoz87
#5 Post by mattywoz87 » Sun Apr 10, 2022 5:23 pm
Good point, hopefully the key will be produced soon then as i sent the dump file on 4th April.
awdspyder
#6 Post by awdspyder » Mon Apr 11, 2022 8:31 pm
I can confirm the key previously worked fine on 1/18/2020. Is the UID in the General MediaInfo relevant in this instance?
