darrrkmanxxx
#6331 Post by darrrkmanxxx » Fri Apr 08, 2022 6:56 am
Yoshitaka wrote: Fri Apr 01, 2022 10:02 pm
Yoshitaka wrote: Sun Mar 27, 2022 1:46 am I have remuxed an HEVC with ac3 to make a dv mp4 but it is stuttering on my C9.. Playing through USB port and flagged as Dolby Vision no problem, no pink video, but just extremely choppy. Stop and start. Audio is in sync too with it..
What could be some problems that have caused this? I've never had this issue before..
Bump. In case my post became buried.
Hey I have that too with p5 or p8 mp4. You can just drag and drop the file into mkvtoolnix and remux to mkv. It will play without stutters and the dolby vision will be kept. I usually playback those with just Player or vimu. Mkv work a lot better than mp4
jiggajim
#6332 Post by jiggajim » Fri Apr 08, 2022 1:39 pm
jiggajim wrote: Wed Apr 06, 2022 8:08 pm
whatsmyname wrote: Sat Jul 17, 2021 11:20 pm Does anyone know if the new Reavon player can play Dolby Vision .mkv?
I've got the UBR-X110, and trying out the DV samples from makemkv via the network interface:
- P4 - Audio/Video worked, no HDR, no DV
- P5 - Audio worked, Video colors off, no HDR, no DV
- P7 (MEL) - Audio/Video worked, HDR worked, no DV
- P7 (FEL) - Audio/Video worked, HDR worked, no DV
- P8.1 - Audio/Video worked, HDR worked, no DV
So no DV on any of the profiles. Womp womp.
Someone else asked but the port is Gigabit. It's showing GbE in my Unifi console.
Just got a note back from support after trying a couple other remuxed formats:
thank you for your message.
We are sorry to inform you that Dolby Vision in video files playback is not supported.
Dolby Vision is only supported with UHD 4K Blu-ray discs.
#6333 Post by RESET_9999 » Fri Apr 08, 2022 11:04 pm
Gatorman wrote: Thu Apr 07, 2022 11:40 pm @RESET_9999
I updated the scripts, input with special characters/ no space should work now. Thanks!
darrrkmanxxx wrote: Fri Apr 08, 2022 6:56 am Hey I have that too with p5 or p8 mp4. You can just drag and drop the file into mkvtoolnix and remux to mkv. It will play without stutters and the dolby vision will be kept. I usually playback those with just Player or vimu. Mkv work a lot better than mp4
TVs dont support DV MKVs.
k9952000 wrote: Thu Apr 07, 2022 11:22 pm So I have a question I have a few files withdolby vision hdr :
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
These play with a green shine, is there any way to just rip the dolby vision out?
Tried a few ways even those (i believe) mentioned in this thread but none seem to work.
Some devices can tonemap it on the fly to HDR10 or SDR such as the Firestick TV (latest one), Sony x700/x800m2, Windows 10 Movies and TV app.
Yep, I have the same problem with some DV MP4. I switched to the TS container and I never had the stuttering issues again with DV. You just have to keep the subtitles externally.
tsmuxer: https://github.com/justdan96/tsMuxer/releases
darrrkmanxxx
#6334 Post by darrrkmanxxx » Sat Apr 09, 2022 11:41 am
RESET_9999 wrote: Fri Apr 08, 2022 11:04 pm
Where do you get that from? You can easily play with Vimu apk or Just player. Dolby Vision and Atmos will be triggered, even the notification appears and there‘s a clearly difference to normal HDR
#6335 Post by RESET_9999 » Sat Apr 09, 2022 2:13 pm
darrrkmanxxx wrote: Sat Apr 09, 2022 11:41 am Where do you get that from?
Literally everywhere!
this is the first time I hear that TVs internal player can play DV MKVs.
Baer2021
#6336 Post by Baer2021 » Sun Apr 10, 2022 12:36 am
Hello all,
I cannot for the life of me figure out how to get my Oppo UDP-203 (stock firmware) to play a .ts or .m2ts file correctly with Dolby Vision. Full-folder backup embedded in a AVCHD file works fine, but I'd really like to get down to individual titles especially for 4K titles like Game of Thrones with multiple episodes and default lossy audio.
I am using the latest tsmuxer 2.6.12 to demux the 2160p and 1080p video layers along with audio tracks, and then remuxing into a single .ts or .m2ts file. With either option, the result is that my Oppo will only play in HDR10 even though MediaInfo shows that both video tracks end up in the resulting .ts file, though it does still show them as separate video streams when I check the file.
I've also tried using the resulting MKV from running through MakeMKV once it has pared the video track down into a single video stream, but tsMuxer is still just presenting a HDR10 track to my Oppo.
Any ideas on what I'm missing?
Yoshitaka
#6337 Post by Yoshitaka » Sun Apr 10, 2022 7:36 am
[/quote]
Hmmm Which option would I select from your .bat going from bdmv, or even mkv dv that's already dv, to a dv format the lg c9 can handle?
Yoshitaka
#6338 Post by Yoshitaka » Sun Apr 10, 2022 7:41 am
[/quote]
[/quote]
I am using an LG C9 and do not have an external player. The LG C9 as far as we all know, only plays mp4s ts and m2ts files that are DV.
ArArdin
#6339 Post by ArArdin » Sun Apr 10, 2022 11:18 am
I thought Oppo suffered from a lock-up when playing two DV ts files sequentially, or has this been fixed meanwhile? Anyways, did you try latest nightly build of tsMuxer?
To my knowledge tsMuxer can't de-interleave BL and EL from a single videotrack - as used in mkv. It can demux/remux them from/to separate videotracks.
darrrkmanxxx
#6340 Post by darrrkmanxxx » Sun Apr 10, 2022 4:16 pm
Yoshitaka wrote: Sun Apr 10, 2022 7:41 am
[/quote]
[/quote]
I have Philips 65OLED934 from 2019 and can play dv mkv through plex or vimu without any external player.
#6341 Post by RESET_9999 » Sun Apr 10, 2022 4:20 pm
Yoshitaka wrote: Sun Apr 10, 2022 7:36 am Hmmm Which option would I select from your .bat going from bdmv, or even mkv dv that's already dv, to a dv format the lg c9 can handle?
from BDMV: Mode P7 (3) ---> Mode 1 (1) ---> Workflow 1 (1)
from MKV P7: Mode P7 (3) ---> Mode 2 (2) ---> Workflow 2 (2)
then tsmuxer nightly to mux the output files. There are also the same workflows in the mp4muxer modes.
darrrkmanxxx wrote: Sun Apr 10, 2022 4:16 pm I have Philips 65OLED934 from 2019 and can play dv mkv through plex or vimu without any external player.
good to know.
LG TVs dont support DV MKV
darrrkmanxxx
#6342 Post by darrrkmanxxx » Sun Apr 10, 2022 6:07 pm
RESET_9999 wrote: Sun Apr 10, 2022 4:20 pm
good to know.
Ok, got you. Sorry for the misunderstanding.
dompidu
#6343 Post by dompidu » Mon Apr 11, 2022 3:27 pm
Hey, has anyone had any problems to get to play Spider-Man No Way Home DV P7 Framestor Remux in the Sony X700?
I converted the mkv to m2ts using latest nightly tsmuxer but the player freezes and shows a black screen, nothing ever plays.
Is there something I may be doing wrong? Thanks.
#6344 Post by RESET_9999 » Mon Apr 11, 2022 5:23 pm
dompidu wrote: Mon Apr 11, 2022 3:27 pm Hey, has anyone had any problems to get to play Spider-Man No Way Home DV P7 Framestor Remux in the Sony X700?
Normal... all the MEL 2mbps movies muxed in ST-DL wont work on the x700/x800m2 ( some fel movie as well).
If you demux and remux to DT-DL, it will work. You can also convert it to profile 8 since its a mel movie, you wont lose any quality.
ArArdin
#6345 Post by ArArdin » Mon Apr 11, 2022 9:48 pm
RESET_9999 wrote: Mon Apr 11, 2022 5:23 pmall the MEL 2mbps movies muxed in...
Anybody knows if or what is wrong with titles that carry a 2mbps MEL? Figuring that MEL is just a placeholder for RPU, I wonder what other crap is stored within to make up for this high bitrate. I'm comparing to other titles with MEL going @ 60 - 90 kbps.
