Hell or High Water Volume Key Unknown
mattywoz87
Post by mattywoz87 »
Trying to backup hell or high water uhd us disc. Got the message that the volume is unknown which i thought was strange since the disc was released in 2018. Sent the dump file to svq@makemkv.com on 4th April but still getting the same message.
Any ideas?
Re: Hell or High Water Volume Key Unknown
Fixing Volume Key is Unknown
Try reading through that.
mattywoz87
Thanks, there nothing listed there that will help though unless the key has not been produced yet which i find hard to believe. I've backed up over 100 uhd discs without problems.
Sometimes new pressings or different versions of the disc end up with different keys. In a quick search of this forum, I didn't find a post where someone mentioned they submitted a key originally, so I have no idea if your key, "0F3D", is new or not.
mattywoz87
Good point, hopefully the key will be produced soon then as i sent the dump file on 4th April.
awdspyder
Post by awdspyder »
I can confirm the key previously worked fine on 1/18/2020. Is the UID in the General MediaInfo relevant in this instance?
