Scream (2022)
looner
Scream (2022)
Post by looner »
i've attached the dump file here.
Re: Scream (2022)
Did you also submit it to svg@makemkv.com ? Email is the only way to submit dump files...
Re: Scream (2022)
Fixing Volume Key is Unknown
Step one: Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
lfoust
Re: Scream (2022)
Post by lfoust »
I was able to rip the disc and here is how the contents layed out for me on the US 4K Steelbook: https://thediscdb.com/movie/scream-2022 ... -steelbook
