Only converting part of title
remko
Post by remko » Sat Apr 09, 2022 8:23 pm
I have a DVD with a track of 372 Mb:
Screenshot 1.png (385.73 KiB) Viewed 3992 times
When I convert this to MKV, it only converts a small portion of it:
Screenshot 2.png (405.32 KiB) Viewed 3992 times
The output size is only 35Mb. The file has 17 chapter markers (as expected), but the chapter markers are all .04seconds long (except the last chapter, which extends to the full length of the track).
I tried using the DVD as source, and tried using an ISO (which I got from a different drive using a different program), both have the same effect.
I tried opening the ISO with Handbrake, and Handbrake converts the entire file.
I'm not seeing any errors during conversion. When opening the ISO, the only suspicious lines I see are:
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Is there anything I can do to help debug this issue?
Beastmaster451
Re: Only converting part of title
Post by Beastmaster451 » Fri Jun 24, 2022 12:13 pm
Shouldn't you be ripping the one with 22 Chapters - 1.8 GB?
