Apocolypse Now 4K UK Import
bobrpggamer
Post by bobrpggamer »
I was able to backup disk 1 UHD, but not Disk 2 UHD. I got the "The volume key is unknown for this disc - video can't be decrypted" report, I am not certain how to report this but I have a logfile that goes with it. Again this would be the Studio Canal 03/28/2022 UK import version not the Lionsgate version.
MKB20_v70_Apocalypse_Now_-_UHD_FDB5.tgz
I guess this is the log file you would need, after seeing other posts.
(228.21 KiB) Downloaded 258 times
Re: Apocolypse Now 4K UK Import
Fixing Volume Key is Unknown
Step one: Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
bobrpggamer
Thank you fro your response. I sent the message with the log file to: "svq@makemkv.com".
Hopefully It is in fact a hash key problem and not a bad disk.
Thank you again dcoke22.
