Godfather II & III issues
Re: Godfather II & III issues
BDR-212UBK. Don't know if that's the "best" Pioneer drive but it works very well for me. It's slow...4x max for UHD. I think that's part of its charm, however, when it comes to these stupid problematic discs. I read all 3 of my Godfather discs with that drive and had zero problems.
I also have a Pioneer BDR-212UBK drive which has been working well.
UHDRips
dcoke22 wrote: Wed Mar 30, 2022 3:48 pm I also have a Pioneer BDR-212UBK drive which has been working well.
SamuriHL wrote: Wed Mar 30, 2022 2:58 pm BDR-212UBK. Don't know if that's the "best" Pioneer drive but it works very well for me. It's slow...4x max for UHD. I think that's part of its charm, however, when it comes to these stupid problematic discs. I read all 3 of my Godfather discs with that drive and had zero problems.
Thank you dcoke22 and SamuriHL
omk1980
Do you think the bu40n or any troubleshooting would get passed a scratch like this on my godfather 2 disk?SamuriHL wrote: Tue Mar 29, 2022 12:06 pm It's set using registry entries so if you didn't explicitly set it, then it's disabled.
As for drives I only recommend bu40n or pioneer drives these days. Pioneer are slower but read very well. The bu40n is like a tank. It reads everything I've thrown at it except physically damaged discs.
https://imgur.com/a/tMswk0A
Physically scratched discs are almost always unrecoverable. Doesn't matter what drive you use. The data is so packed on these discs that a scratch renders it pretty useless most of the time.
omk1980
Yeah, my wh16ns60 has been great thus far. Hopefully the replacement is better.SamuriHL wrote: Fri Apr 08, 2022 12:11 am Physically scratched discs are almost always unrecoverable. Doesn't matter what drive you use. The data is so packed on these discs that a scratch renders it pretty useless most of the time.
omk1980
Was able to get a replacement disc and was able to backup w/o issue. Thanks everyone for their help.
omk1980
looked like that godfather disc was scratched. was able to rip a copy. is keeping the read speed unlimited going to introduce errors in ripping w/the wh16ns60? right now the value is set to 0, not 0=99, but when i open up makemkv, unrestricted read speed is listed as "yes". What do i change the registry value to if i want to go back to the default?
Delete the registry entry if you want to default it. That's the easiest way.
omk1980
so in windows, in registry editor, delete the "speed_HL-DT-ST...." file? will it recreate a new file when makemkv starts back up?
Just delete the data in that string. You don't have to delete the key itself. Just make the value blank.
omk1980
Weird. I did that and it still shows unrestricted read access. I also uninstalled makemkv, deleted the makemkv registry files and reinstalled and it's still there. I guess it'll always be on. Hope it doesn't lead to more read errors.SamuriHL wrote: Thu May 12, 2022 2:22 am Just delete the data in that string. You don't have to delete the key itself. Just make the value blank.
As you saw in the other thread it'll always tell you the capability is there but it's not activated if the key isn't set.
omk1980
Thanks for the reply.
