LG BP60NB10 External Drive
strubdog
So I'm upgrading from the Archgon MD-8107S-U3-UHD external drive to an LG BP60NB10 External Drive. The reason I'm upgrading is that the Archgon was causing circular scratches on my disc's from time to time.
What are people's experiences with the LG drive. Am I getting a good one or should I send it back to Amazon after I receive it?
Re: LG BP60NB10 External Drive
Well, it's not really an upgrade as they are essentially the same hardware. The LG is in a plastic enclosure whereas the Archgon isn't. Give the LG a try and see how you go.strubdog wrote: Fri Mar 25, 2022 1:42 am So I'm upgrading from the Archgon MD-8107S-U3-UHD external drive to an LG BP60NB10 External Drive. The reason I'm upgrading is that the Archgon was causing circular scratches on my disc's from time to time.
Make sure wherever you put the drive, it is level as I find circular scratches happen when the drive is running and it is not level.
strubdog
I just received my drive. It shows as having firmware version 1.02. Do I still need to flash this?
What does MakeMKV report in the Drive/LibreDrive info sections? You can copy/paste.
Yes it had encrypted firmware and needs to be flashed.strubdog wrote: Fri Apr 01, 2022 8:45 pm I just received my drive. It shows as having firmware version 1.02. Do I still need to flash this?
strubdog
Can you point me to the specific post or firmware I should be using?
link belowstrubdog wrote: Wed Apr 06, 2022 10:53 pm Can you point me to the specific post or firmware I should be using?
strubdog
I read the guide beforehand. Here is the entry I'm confused about:
"BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
BP60NB10 on any Firmware directly to > BP60NB10 1.02MK"
It looks like it references 2 different drives.
It is 2 references for 2 drives. You have a BP60NB10 so you should only concern yourself with "BP60NB10 on any Firmware directly to > BP60NB10 1.02MK"strubdog wrote: Thu Apr 07, 2022 4:22 am I read the guide beforehand. Here is the entry I'm confused about:
You said your's came with 1.02, so flash it to BP60NB10 1.02-MK and done! Start ripping.
strubdog
Which thread has the link to this specific firmware?
strubdog
Disregard, I was able to get it flashed.
corefunctions
I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
Install MakeMKV in the default location.corefunctions wrote: Wed Jan 15, 2025 8:03 am I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
corefunctions
I did install MKV on my mac but my Mac isn't able to open the SDFTool software. I tried using my friends PC to add the software. He doesn't have MKV downloaded on his PC.MartyMcNuts wrote: Wed Jan 15, 2025 11:06 pmInstall MakeMKV in the default location.corefunctions wrote: Wed Jan 15, 2025 8:03 am I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
SDFTool Flasher is a Windows only frontend GUI for the MakeMKV command line. MakeMKV must be installed to use it.corefunctions wrote: Fri Jan 17, 2025 6:21 pmI did install MKV on my mac but my Mac isn't able to open the SDFTool software. I tried using my friends PC to add the software. He doesn't have MKV downloaded on his PC.MartyMcNuts wrote: Wed Jan 15, 2025 11:06 pmInstall MakeMKV in the default location.corefunctions wrote: Wed Jan 15, 2025 8:03 am I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
