Guide to flash new LG WH16NS60?
I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
Re: Guide to flash new LG WH16NS60?
Link belowboolian2 wrote: Wed Apr 06, 2022 3:17 pm I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
Does the LG Flasher flash both the correct firmware and LibreDrive? Or is LibreDrive THE firmware?Billycar11 wrote: Wed Apr 06, 2022 10:43 pmLink belowboolian2 wrote: Wed Apr 06, 2022 3:17 pm I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
Flashing the firmware will enable libredriveboolian2 wrote: Thu Apr 07, 2022 6:03 amDoes the LG Flasher flash both the correct firmware and LibreDrive? Or is LibreDrive THE firmware?Billycar11 wrote: Wed Apr 06, 2022 10:43 pmLink belowboolian2 wrote: Wed Apr 06, 2022 3:17 pm I just got a LG WH16NS60, is there a guide out there to flash it with the old firmware, and also LibreDrive? Are those 2 separate things? I'm using an OWC Mercury Pro external optical drive enclosure to connect the LG to my computer. Thanks
I just flashed it with 1.02, it said operation successful. But in MakeMKV it still says the drive is 1.03.Billycar11 wrote: Thu Apr 07, 2022 6:10 amFlashing the firmware will enable libredriveboolian2 wrote: Thu Apr 07, 2022 6:03 amDoes the LG Flasher flash both the correct firmware and LibreDrive? Or is LibreDrive THE firmware?
EDIT: I was using command line before (unencrypted firmware command), I just used "SDF" GUI tool (said encrypted firmware) and MakeMKV now says 1.02. But what does "microcode access re-enabled" mean? Also, does 1.02 have the drive sleep bug? My old WH16NS60 is 1.00, should I also flash new drive with 1.00 instead of 1.02?
I used the 5.25 Desktop LG firmware from the "all you need" firmware pack on Google Drive link on your thread.
Both are fine go to 1.00 if you use other rippers that are not makemkv or anydvdboolian2 wrote: Mon Apr 18, 2022 3:00 amI just flashed it with 1.02, it said operation successful. But in MakeMKV it still says the drive is 1.03.Billycar11 wrote: Thu Apr 07, 2022 6:10 amFlashing the firmware will enable libredriveboolian2 wrote: Thu Apr 07, 2022 6:03 am
What about DVDFab? Does 1.02 work with itBillycar11 wrote: Mon Apr 18, 2022 5:05 amBoth are fine go to 1.00 if you use other rippers that are not makemkv or anydvdboolian2 wrote: Mon Apr 18, 2022 3:00 amI just flashed it with 1.02, it said operation successful. But in MakeMKV it still says the drive is 1.03.
You're correct, 1.02 doesn't work with DVDFab. I just tried it. I will downgrade to 1.00.Billycar11 wrote: Mon Apr 18, 2022 11:38 pmgo to 1.00 if you use other rippers that are not makemkv or anydvd
Phoenix0870
Hello.
LG WH16NS60 V1.00 is compatble all ripprograms, ok.
Which version is better in reading and writing?
(LG WH16NS60: V1.03/V1.02/V1.01/V1.00)
Is V1.03 faster than V1.02?
Is V1.02 faster than V1.01?
Is V1.01 faster than V1.00?
all the same pretty muchPhoenix0870 wrote: Sat Sep 28, 2024 6:35 am Hello.
