Halloween Scream Factory UHDs
Nobody mentioned it but I received Halloween and Halloween II UHD yesterday and they’re not decrypting. Submitted the dump. Anyone have any luck? I think they came out a little early than release date at BB. The others come out Oct. 5
Re: Halloween Scream Factory UHDs
i was wondering the same thing. i submitted the dump for the first one on Wednesday.
is there a particular process to follow to try to decrypt the disc that someone else can try like myself?
i have a programming background if that helps.
I only have 1 so far. The others proved harder to get. Anyway 1 decrypted just fine for me.
I was able to rip I, III, 4, and 5 without any issues. I don't have II yet.
I do have an ASUS BW-16D1HT which uses LibreDrive that that might be why.
Just got Halloween 4K Scream Factory disc, couldn't rip it. Submitted the dump to the email. Edit: update May 2022 - I can now rip it. Thanks goodness, I thought Scream/Shout factory discs just couldn't be ripped.
