How to create a new remuxing profile?
Ferrett1983
#1 Post by Ferrett1983 » Thu Nov 25, 2021 3:57 pm
Hi basically I want to create a new profile but I'm unsure on how to do so. Basically I would like all LPCM and 1.0/2.0 DTS-HD MA tracks to be converted to FLAC. Also I would like all video tracks language to be undetermined instead of eng and also no names for audio tracks e.g stereo, mono etc I just want a clean blu ray remux and for their to be the same consistency across all remuxes.
wcndave
Re: How to create a new remuxing profile?
#2 Post by wcndave » Thu Mar 31, 2022 1:30 pm
There is a sticky at the top of this board, that talks about how to edit a profile.
However what it doesn't cover, is where to get the profiles file in the first place - to make edits to.
"In order to make a profile visible in GUI, the conversion profile file ( with .mmcp.xml extension ) must be placed into MakeMKV data directory which can be looked up and changed in preferences."
I have a custom profile from 10 years ago, and I wonder if it's wrong, because it's out of date.
I'd like to create a new clean one, however from what?
I'm pretty sure when I did this years ago, I turned off advanced, it created a default.xml file, then I copied that. However now, it appears there's no default file anymore, so I have no "template" on which to build a profile file.
Any thoughts on how to do this?
Chetwood
#3 Post by Chetwood » Sat Apr 02, 2022 11:30 am
The default.mmcp.xml is stored inside the appdata.tar that's stored to the MakeMKV program directory, at least on Windows.
wcndave
#4 Post by wcndave » Sat Apr 02, 2022 4:44 pm
ok, thanks! I would never have though to look in there!
