Cinema Libre Ukraine on Fire BD
Ripman
Post by Ripman » Tue Mar 29, 2022 5:35 pm
Hi everyone. Long time for sure. MakeMKV 1.16.3. I realize this is a few versions behind.
I got the BD Ukraine on Fire from the CInema Libre store. It's a real BD not a BDR. I put the disc in and I get a "code 3".
Sometimes drives are "picky" with certain discs, and that's the feeling I get with this one. Just the same, I figured I'd post and see what the forum had to say. Log is below. Thanks.
MakeMKV log
Debug log started at Tue Mar 29 15:21:22 2022 , written by MakeMKV v1.16.3 win(x64-release)
001005:0000 MakeMKV v1.16.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\user/MakeMKV_log.txt
005075:0000 The new version 1.16.7 is available for download at http://www.makemkv.com/download/
No  SDF v088: MATSHITA_DVD-RAM_UJ8E1_1.00_20000000000000_1418TP256537
DEBUG: Code 3 at HFuPt/Gy+]n6ub.|sx^Z;r\.:29395310
SDF id v088: MATSHITA_DVD-RAM_UJ8E1_1.00_20000000000000_1418TP256537
SDF  v088: HL-DT-ST_BDDVDRW_CP50NS20_1.00_211409041512_MZ6E9PF2736
Ripman
Re: Cinema Libre Ukraine on Fire BD
Post by Ripman » Tue Mar 29, 2022 8:13 pm
I've seen some of the LIbre Drive posts from June-2020, so I will try some of the options explained in those threads.
Drive info:
OS device name: F:
Product: BDDVDRW CP50NS20
Revision: 1.00
Serial number: MZ6E9PF2736
Firmware date: 2114-09-04 15:12
Bus encryption flags: 16
Highest AACS version: 70
Firmware version: 1.00
BD raw metadata read: Partial
Post by dcoke22 » Tue Mar 29, 2022 9:00 pm
Have you tried the newer version of MakeMKV? I have no idea if it'll fix your problem, but it would seem to be an easy thing to try.
Ripman
Post by Ripman » Tue Mar 29, 2022 9:25 pm
Hi. Thanks. I unplugged the USB BD drive and rebooted. It worked fine.
This was one of the suggestions from Mike the Admin in the "code 3" thread, which I've put below.
viewtopic.php?f=19&t=22509&p=120714#p120714
