Need Help Flashing New Drive
Humble
Re: Need Help Flashing New Drive
Post by Humble » Tue Mar 29, 2022 9:09 am
these are Blu-ray original discs.
1. Fantastic beasts and where to find them - UHD Blu-ray (HDR)
2. Atomic Blonde - Standard Blu-ray
3. John Wick 3 - Standard Blu-Ray
I buy all my discs from official outlets.
Post by Billycar11 » Tue Mar 29, 2022 10:06 am
Humble wrote: Tue Mar 29, 2022 9:09 am these are Blu-ray original discs.
well there possibility's then
1. bad or dirty discs but unlikely with all of them try cleaning
2. another program trying to do something with the discs
3. dirty drive laser
4. your psu is junk and cant power the drive pretty unlikely
5. defective drive
Humble
Post by Humble » Tue Mar 29, 2022 10:13 am
Well I just took the plastic off all of them lol. All brand new.
I'm running a 600W power supply that powers my GTX 1080 when I'm gaming so ill count that one out.
I wasn't running any other programs at the time.
I was thinking to try another drive.
I messaged you from e-bay
Post by Billycar11 » Tue Mar 29, 2022 10:23 am
Humble wrote: Tue Mar 29, 2022 10:13 am Well I just took the plastic off all of them lol. All brand new.
im not on ebay
is someone claiming to be me?
Humble
Post by Humble » Tue Mar 29, 2022 10:58 am
Sry for the confusion.
I followed one of the links you posted and I was talking the the UK seller. For some reason I originally thought it was you. But it was my mistake.
He is recommending that i buy the (BDR-S12UHT) does anyone here recommend this drive?
I don't want to spend the money for something that doesn't work [again]
Post by Billycar11 » Tue Mar 29, 2022 11:05 am
Humble wrote: Tue Mar 29, 2022 10:58 am Sry for the confusion.
ok no problem i only ship to the usa so if your here order from me or if you in uk order from him
i highly recommend you go with a BU40N or bp60 whoever you buy from
Humble
Post by Humble » Tue Mar 29, 2022 12:09 pm
I attempted one last try by disconnecting the power cable from the drive and re-attaching it.
as a miracle it started to work, until around 50% then gave me some errors:
The source file '/BDMV/STREAM/00245.m2ts' is corrupt or invalid at offset 18242002944, attempting to work around
The source file '/BDMV/STREAM/00245.m2ts' is corrupt or invalid at offset 18242002944-18242009088, attempting to work around
The source file '/BDMV/STREAM/00245.m2ts' is corrupt or invalid at offset 18242009088, attempting to work around
Hash check failed for file 00245.m2ts at offset 18242070528, file is corrupt.
Hash check failed for file 00245.m2ts at offset 18242267136, file is corrupt.
Hash check failed for file 00245.m2ts at offset 18242463744, file is corrupt.
Hash check failed for file 00245.m2ts at offset 18242660352, file is corrupt.
Too many hash check errors in file 00245.m2ts.
The source file '/BDMV/STREAM/00245.m2ts' is corrupt or invalid at offset 18246715392, attempting to work around
The source file '/BDMV/STREAM/00245.m2ts' is corrupt or invalid at offset 18308911104, attempting to work around
Is there some hope still?
I tried it twice and twice the same response.
Post by Billycar11 » Tue Mar 29, 2022 12:55 pm
Humble wrote: Tue Mar 29, 2022 12:09 pm I attempted one last try by disconnecting the power cable from the drive and re-attaching it.
I'm not really sure man If the drive is brand new it's probably defective.
But as been said many times even new discs need to be cleaned sometimes worth a try
Humble
Post by Humble » Tue Mar 29, 2022 1:38 pm
Small update.
So I've been troubleshooting all day and I decided to mess with the Java side of things.
MakeMKV was using Java through a third party program, so I removed that program because it was just experimental and installed java separately and now my first blu-ray rip is complete.
I'll try the next discs and give more feedback.
Post by Billycar11 » Tue Mar 29, 2022 1:52 pm
Humble wrote: Tue Mar 29, 2022 1:38 pm Small update.
I don't believe java would cause that it's only used to figure out playlists
Humble
Post by Humble » Tue Mar 29, 2022 4:24 pm
Final update on this topic.
So far the drive is working. I'm currently on my 5th disc.
my drive is a LG BH16NS40 and it came with a v1.05 firmware.
in summary what I did was:
flash the firmware to the WH16NS60 v1.02 using the SDFtool Flasher v1.3.3
the firmware is located in "The all you need firmware pack"
after flashing the firmware I disconnected the power sata cable from the drive then reconnected it. (Maybe a pc reboot may help, but it didn't work for me)
I then updated my Java software.
Hopefully this may help someone.
And also thanks to the community. I'll def. be contributing because I believe that we need to keep this project going.
ineedhelp
Post by ineedhelp » Tue Mar 29, 2022 7:16 pm
Hello! I also have an Archgon drive I got recently, and I want to save my 4Ks with it. This is where I got it from: https://www.amazon.com/Archgon-Premium- ... B07BC9F98J
Here are the specifications listed by MakeMKV:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO9L91G5925
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I've read many of the forums guiding how to flash the drive, and I believe I know how to flash, but my question is this: Which firmware is the safest/best to flash my drive with? My goal is to save my Blu-ray and 4K films in a file container compatible with most players (The MKV format seems very versatile).
I've been made aware by this forum -- viewtopic.php?f=16&t=19634 -- Recommends firmware "1.03MK" for Archgon BU40N, which my drive seems to be, but reading this article, Marty recommends 1.00 (DE, I assume). I've contacted AVSForum here -- https://www.avsforum.com/threads/rippin ... 0/page-217 (at the very bottom of the page, currently) -- A registered member has assured me that the 1.04MK that I've already downloaded, ready to flash my drive with, would also work.
I would like to know from the best which would be the best for my preferences. If I must flash the drive twice or more, please let me know. Thank you in advance.
Post by Billycar11 » Tue Mar 29, 2022 10:50 pm
ineedhelp wrote: Tue Mar 29, 2022 7:16 pm Hello! I also have an Archgon drive I got recently, and I want to save my 4Ks with it. This is where I got it from: https://www.amazon.com/Archgon-Premium- ... B07BC9F98J
Revision: 1.02
Follow the guide below
ineedhelp
Post by ineedhelp » Wed Mar 30, 2022 12:54 am
Billycar11 wrote: Tue Mar 29, 2022 10:50 pm
So, basically, any MK version, or just 1.00 if not, right?
Post by Billycar11 » Wed Mar 30, 2022 1:25 am
ineedhelp wrote: Wed Mar 30, 2022 12:54 am
i prefer to keep the flashing when done by other to the leas amount of steps as possible to a firmware that always works.
so i recommend BU40N 1.03mk if you use makemkv if you use other rippers that dont work with 1.03mk then downgrade from there to 1.00.
