I've got an Asus BW-16D1X-U which, as we all know, isn't UHD compatible. If I get one of the UHD-friendly internal drives, I'd like to re-use that enclosure rather than buying a new one.
Assuming the new drive physically fits, would there be any problem with firmware flashing, UHD ripping, or anything else? Would the old enclosure prevent the drive from being recognized as UHD compatible?
Reuse enclosure from Asus BW-16D1X-U
Re: Reuse enclosure from Asus BW-16D1X-U
Some actually are UHD capable now they changed the drive again what your drive info.
But yes you can reuse the case
uid000
Great, thanks for the advice.Billycar11 wrote: Wed Mar 23, 2022 10:11 pm Some actually are UHD capable now they changed the drive again what your drive info.
How can I tell if the drive is UHD capable? Do I need to physically look at the internal drive?
Here's a screenshot of what MakeMKV shows
Yeah that can do UHDuid000 wrote: Sat Mar 26, 2022 10:52 pmGreat, thanks for the advice.Billycar11 wrote: Wed Mar 23, 2022 10:11 pm Some actually are UHD capable now they changed the drive again what your drive info.
