No disc Inserted Issue
Re: No disc Inserted Issue
If it's an external drive, power it down for a few minutes.
If it's internal, power down the PC for a few minutes.
Power up again & see if things are better behaved.
I've got the same issue.
I tried reinstalling the application and I deleted the permissions in Security & Privacy >> Files and Folders: MakeMKV.app Removable Volumes.
Now I don't get the prompts to grant access again. I had to manually add the app to Full Disk Access, but it still does not have access to Removable Volumes.
I'm not sure if reading the discs are a problem specific to MakeMKV. VLC doesn't see the discs and neither does the DVD Player.app.
I was trying to set up VLC to use MakeMKV to decrypt.
My drive is an ASUS BW-16D1X-U. I'm on macOS Monterey 12.2.1
argh...my issue ended up being my drive quit spinning. Everything works fine for me after the replacement.
I did not get an error/request to grant access to the removable volume after replacing the drive.
I updated yesterday, and now I am also having this issue.
d00zah's recommendation still stands. Try 'rebooting' the drive. There's a tiny computer inside the drive that controls the laser, motor, the works. Sometimes it needs to be rebooted. The only way to do it is to remove power from the drive then plug it back in. If it is external, flip the power switch or unplug the cables for a bit then try again. If it is internal, power down the PC and perhaps unplug it to make sure power is really gone, then try again.
It's external:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLFJB685514
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
I've tried unplugging and plugging it back in. How long would you leave it unplugged for? Should I try re-flashing it?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Re-flashing the drive did not fix the problem. I do not understand what could be causing this.
You will have to take the drive out and tell us the info on the label maybe your drive was to old to flashbigmack3000 wrote: ↑Fri Apr 01, 2022 10:10 pmRe-flashing the drive did not fix the problem. I do not understand what could be causing this.
Unless you remember the drive info from before the flash then tell use that
It's a ASUS BW-16D1HT. It was flashed to 3.10 and worked perfectly up until yesterday when I started getting the error. So I thought flashing it again might reset it. But no go.Billycar11 wrote: ↑Fri Apr 01, 2022 11:01 pmYou will have to take the drive out and tell us the info on the label maybe your drive was to old to flashbigmack3000 wrote: ↑Fri Apr 01, 2022 10:10 pmRe-flashing the drive did not fix the problem. I do not understand what could be causing this.
They do have a habit of dying do a full shutdown and see if it comes back after that
You can also test if DVDs work and if just the bluray laser died
DVD had the same error. Would it die so suddenly? The disc before it stopped went perfectly. Is it worth bringing it somewhere or just replacing?Billycar11 wrote: ↑Sat Apr 02, 2022 12:19 amThey do have a habit of dying do a full shutdown and see if it comes back after that
just replace,bigmack3000 wrote: ↑Sat Apr 02, 2022 2:22 amDVD had the same error. Would it die so suddenly? The disc before it stopped went perfectly. Is it worth bringing it somewhere or just replacing?Billycar11 wrote: ↑Sat Apr 02, 2022 12:19 amThey do have a habit of dying do a full shutdown and see if it comes back after that
go for a BU40N or BP60NB10 or even a pioneer
I started getting this error yesterday after months without issues with 4K discs. I put in a regular Blu-Ray disc and it read it fine, but for some reason 4K discs seem to be a problem all of a sudden, including ones that have not had issues in the past.
I have powered the whole system down and brought it back up, with no success. Any help will be appreciated.
OS device name: \Device\CdRom2
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Serial number: KLCO82A4130
Firmware date: 2117-03-31 14:26
Highest AACS version: 77
Firmware version: 3.01
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
