I followed the instructions like in the video, and then used mkvtoolmix from your app as suggested by you.RESET_9999 wrote:I just tested my Shield and MKV/TS p8 + atmos file created by my script are working. Are you using mkvtoolnix or tsmuxer included in my tools pack?
i created a mkv file with it
if you wish more info on my file i can give you that info, or just give you the files.
