install makemkv on Debian without snap
vikozo
Post by vikozo »
hello
is there a way - tutorial - how to install makemkv on
Kernel: 5.16.0-4-amd64 x86_
Distro: Debian GNU/Linux 11 (bullseye)
without using snap?
bmillham
Re: install makemkv on Debian without snap
Post by bmillham »
Installation is covered in the pinned post here viewtopic.php?f=3&t=224. I use those instructions for installing on Linux Mint and they work great.
What problems are you having trying to install?
mathias
Post by mathias »
Also, I publish unofficial Debian packages: viewtopic.php?f=3&t=24328
There are filed ITPs with Debian to place MakeMKV in the non-free section of the archive (https://bugs.debian.org/1003815 and https://bugs.debian.org/1005075), so maybe someday you'll be able to install from a Debian mirror.
vikozo
Post by vikozo »
bmillham wrote: Mon Mar 21, 2022 7:28 pm Installation is covered in the pinned post here viewtopic.php?f=3&t=224. I use those instructions for installing on Linux Mint and they work great.
Thanks after a second try it did work, thanks you
demyfevo
Post by demyfevo »
Helpful guide! Installing MakeMKV on Debian without using Snap is a valuable workaround for those who prefer traditional package methods or have Snap disabled. It’d be great to include steps for keeping the software updated manually as well.
