Blu-Ray to Blu-Ray
donpimp
Blu-Ray to Blu-Ray
Post by donpimp »
I am looking to backup my blu-rays. I want to store the copies on media not the hard drive. I read here you first make a MKV then use tsMuxer to create the ISO (which I can then burn).
So as a trial run I copied one of my DVDs (yes DVD) to MKV...success. Played in VLC...success. Then I used tsMuxer to create a Blu-Ray ISO. Then to see if that file worked I played the ISO in VLC...boom no sound! The video looked great but even the Audio Menus were grayed out. This tells me the Audio track didn't come along? What went wrong?
donpimp
Re: Blu-Ray to Blu-Ray
Post by donpimp »
OK the above test was with my lite-on DVD burner. I am now doing the same with a Blu-Ray burner I just bought. So no "DVD" involved this time. So far so good the sound seemed to go with the ISO! I am now trying to get it on to a disc using "isoburn" that comes with Windows10.
Out of curiosity, why are you trying to rip a blu-ray and then burn it back to disc?
donpimp wrote: Fri Mar 25, 2022 4:59 am I am looking to backup my blu-rays. I want to store the copies on media not the hard drive. I read here you first make a MKV then use tsMuxer to create the ISO (which I can then burn).
probably because you created a bluray iso out of a dvd folder structure they have different structures
