Obliver
Post by Obliver » Wed Mar 23, 2022 4:49 pm
I've tried going from a DT-DL Bluray MPLS to MP4 P8 DDP 1536 kbps but Plex app won't recognize it. Workflow is DT-DL Bluray > HEVC P7 SL DL (yuseope) > MKV mux P7 ST DL with Atmos THD > MP4 P8 with DDP 1536 kbps.
This is the end file:
General
Complete name                            : P:\Test\00800_ST-DL_DoVi.sub.au.mp4
Format                                   : mp43
Codec ID                                 : mp43 (isom/mp43/dby1)
File size                                : 23.0 GiB
Duration                                 : 1 h 1 min
Overall bit rate                         : 53.3 Mb/s
Encoded date                             : UTC 2022-03-23 15:43:39
Tagged date                              : UTC 2022-03-23 15:43:39
Writing application                      : GPAC-1.1.0-DEV-rev1027-g1daa0b5f-master
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 51.8 Mb/s
Bits/(Pixel*Frame)                       : 0.260
Stream size                              : 22.3 GiB (97%)
Encoded date                             : UTC 2022-03-23 15:32:04
Tagged date                              : UTC 2022-03-23 15:53:06
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : ec-3
Bit rate                                 : 1 536 kb/s
Maximum bit rate                         : 1 622 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 678 MiB (3%)
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 1 h 0 min
Bit rate                                 : 44 b/s
Stream size                              : 19.3 KiB (0%)
Title                                    : srt@GPAC1.1.0-DEV-rev1027-g1daa0b5f-master
Encoded date                             : UTC 2022-03-23 15:53:06
Does it have to do with the dvhe codec? The following file from the same initial BD with hev1 codec gets recognized fine by Plex:
General
Complete name                            : P:\Backup\S01E01 - Winter is Coming.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 22.6 GiB
Overall bit rate                         : 52.4 Mb/s
Encoded date                             : UTC 2022-03-09 05:28:08
Tagged date                              : UTC 2022-03-09 05:28:08
Video
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Stream size                              : 22.3 GiB (99%)
Codec configuration box                  : hvcC+dvvC
Audio
Format                                   : E-AC-3
Codec ID                                 : ec-3
Stream size                              : 282 MiB (1%)
Alternate group                          : 2
How can I get Plex to recognize them? T_T
Or at least is there a script to go from that Bluray DT-DL to the MP4 with hev1 codec that's recognized by Plex?
Post by RESET_9999 » Wed Mar 23, 2022 5:26 pm
quite possible, I don't use the mp4 container because I think it's garbage so I didn't really test playback on my C8... I know the newer versions of the mp4muxer doesnt work but im using the old version that is supposed to work.
I recommend TS container with external srt subs. Rename same as your ts and add tag in the filename such as ENG.FORCED and plex will pick it up.
woah, that's a lot of remuxing for nothing. You can just use " mp4 mode SL , Workflow.4= MPLS P7 bluray to P8 + EAC3 + SRT subtitles "
BTW, I've tested DGdemux for MPLS input and the next release should be able to convert any TrueHD or DTS track regardless of the track ID.
Obliver
Post by Obliver » Wed Mar 23, 2022 5:55 pm
I've tried using that one, but it always give me the following error of "can't open file". This is with Workflow.3= MPLS P7 bluray to P8 + EAC3 (but it should be the same as the other one, minus the SRT right?).
I'm attaching the .m2ts mediainfo from the original BD STREAM folder after this, just in case.
                                      * DoVi_Scripts @RESET_9999 *
 *The output folder by default is the "Dolby-Vision-Tools" Folder, you can change it by editing this bat file
 *Do not move the bat file out of the "Dolby-Vision-Tools" Folder
 *Select a mode, a workflow. Drag and drop an input file and wait...
                                           * CHOOSE A MODE *
Main Menu
1) MODE.XP= XML and RPU injector
2) MODE.P5= Profile 5 to Profile 8 injector
3) MODE.P7= Profile 7 conversion/muxing/demuxing/injector
4) MODE.H=  HDR10plus to DoVi maker
5) MODE.B=  Batch muxer: MKV to TS (DV/DD+/SUB)
6) MODE.R=  Read/Info/Remover/and more
7) MODE.M=  MadVR HDR10 to DoVi maker
8) MODE.M4= MP4_muxer(p5/P8/P7)
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?8
                                           * CHOOSE A MODE *
Ma
1) MODE.1= single-track (p5, p8, p7)
2) MODE.2= dual-track (p7)
3) MODE.3= Demuxer (p5, p8, p7)
4) MODE.4 = back to main menu
Choice? [1,2,3,4]?1
----------- CHOOSE A WORKFLOW --------------------------------------------------------------------------------------------
1) Workflow.1= HEVC + AC3/EAC3 + SRT subtitle
2) Workflow.2= HEVC + AC3/EAC3
3) Workflow.3= MPLS P7 bluray to P8 + EAC3
4) Workflow.4= MPLS P7 bluray to P8 + EAC3 + SRT subtitles
5) Workflow.5= MKV P7 to P8 + EAC3 + SRT subtitles
6) Workflow.6= back to main menu
Choice? [1,2,3,4,5,6]?3
Drag and drop your BD folder and press enter..."P:\TV Shows\Game of Thrones\Game.of.Thrones.S01.2160p.BluRay.HEVC.TrueHD.7.1.Atmos-HDBEE\DISC1\BDMV"
DGDemux 1.0.0.59 by Donald A. Graft
Copyright (C) 2019-2021 Donald A. Graft, All Rights Reserved [Made in USA]
PlayLists:
00800.mpls 01:01:40 [10 chapters]
00802.mpls 00:57:17 [10 chapters]
00801.mpls 00:55:20 [10 chapters]
Drag and drop the main movie MPLS and press enter..."P:\TV Shows\Game of Thrones\Game.of.Thrones.S01.2160p.BluRay.HEVC.TrueHD.7.1.Atmos-HDBEE\DISC1\BDMV\PLAYLIST\00800.mpls"
demuxing bluray MPLS
tsMuxeR version git-f4fa419. github.com/justdan96/tsMuxer
Can't open file: "P:\TV Shows\Game of Thrones\Game.of.Thrones.S01.2160p.BluRay.HEVC.TrueHD.7.1.Atmos-HDBEE\DISC1\BDMV\PLAYLIST\00800.mpls"
extracting and converting profile 7 to profile 8
Error: Input file doesn't exist.
Press a key to continue . . .
injecting profile 8 into BL
Pesss a key to continue . . .
mkvmerge v66.0.0 ('Josie') 64-bit
Error: The file 'P:\Dolby-Vision-Tools\00800.track_4352_eng.ac3+thd' could not be opened for reading: open file error.
Couldn't find P:\Dolby-Vision-Tools\00800.track_4352_eng.ac3+thd
encoding lossless audio to DD+ 1536kbps
Error: Unknown mode 'P:\Dolby-Vision-Tools\00800_EC3.mkv'.
muxing into a MP4 profile 8 DoVi file. Be patient, it can take a while. 40min+ on slow HDD!!!
ERROR! Can't open input file: P:\Dolby-Vision-Tools\P8.hevc
Error parsing command line!
Couldn't find P:\Dolby-Vision-Tools\00800.track_4113_und.hevc
Couldn't find P:\Dolby-Vision-Tools\00800.track_4117_und.hevc
Couldn't find P:\Dolby-Vision-Tools\00800_EC3.mkv
Couldn't find P:\Dolby-Vision-Tools\P8.hevc
Couldn't find P:\Dolby-Vision-Tools\audio.ec3
Couldn't find P:\Dolby-Vision-Tools\rpu.bin
Couldn't find P:\Dolby-Vision-Tools\THD.mkv
the script has completed...
General
Complete name                            : P:\TV Shows\Game of Thrones\Game.of.Thrones.S01.2160p.BluRay.HEVC.TrueHD.7.1.Atmos-HDBEE\DISC1\BDMV\STREAM\00045.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 31.5 GiB
Overall bit rate                         : 73.0 Mb/s
Maximum Overall bit rate                 : 109 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Video #2
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio #1
Codec ID                                 : 129
Delay relative to video                  : 2 s 2 ms
Audio #2
Format                                   : MLP FBA AC-3 16-ch
Format settings                          : Dolby Surround EX
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 887 kb/s
Audio #3
Codec ID                                 : 129
Stream size                              : 198 MiB (1%)
Audio #4
Codec ID                                 : 129
Bit rate                                 : 256 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Stream size                              : 113 MiB (0%)
Audio #5
Codec ID                                 : 129
Audio #6
Codec ID                                 : 129
Audio #7
Codec ID                                 : 129
Audio #8
Format                                   : DTS
Codec ID                                 : 130
Bit rate                                 : 768 kb/s
Channel layout                           : Lt Rt
Stream size                              : 339 MiB (1%)
Audio #9
Format                                   : DTS
Codec ID                                 : 130
Bit rate                                 : 768 kb/s
Audio #10
Format                                   : DTS
Codec ID                                 : 130
Bit rate                                 : 768 kb/s
Audio #11
Format                                   : DTS
Codec ID                                 : 130
Bit rate                                 : 768 kb/s
Audio #12
Format                                   : DTS
Codec ID                                 : 130
Bit rate                                 : 768 kb/s
Channel layout                           : C L R Ls Rs LFE
Audio #13
Codec ID                                 : 129
Text #1
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 12 s 554 ms
Text #2
Format                                   : PGS
Codec ID                                 : 144
Text #3
Format                                   : PGS
Codec ID                                 : 144
Text #4
Format                                   : PGS
Codec ID                                 : 144
Text #5
Format                                   : PGS
Codec ID                                 : 144
Text #6
Format                                   : PGS
Codec ID                                 : 144
Text #7
Format                                   : PGS
Codec ID                                 : 144
Text #8
Format                                   : PGS
Codec ID                                 : 144
Text #9
Format                                   : PGS
Codec ID                                 : 144
Text #10
Format                                   : PGS
Codec ID                                 : 144
Text #11
Format                                   : PGS
Codec ID                                 : 144
Text #12
Format                                   : PGS
Codec ID                                 : 144
Text #13
Format                                   : PGS
Codec ID                                 : 144
Text #14
Format                                   : PGS
Codec ID                                 : 144
Text #15
Format                                   : PGS
Codec ID                                 : 144
Text #16
Format                                   : PGS
Codec ID                                 : 144
Text #17
Format                                   : PGS
Codec ID                                 : 144
Text #18
Format                                   : PGS
Codec ID                                 : 144
Text #19
Format                                   : PGS
Codec ID                                 : 144
Text #20
Format                                   : PGS
Codec ID                                 : 144
Text #21
Format                                   : PGS
Codec ID                                 : 144
Text #22
Format                                   : PGS
Codec ID                                 : 144
Text #23
Format                                   : PGS
Codec ID                                 : 144
Text #24
Format                                   : PGS
Codec ID                                 : 144
Text #25
Format                                   : PGS
Codec ID                                 : 144
Text #26
Format                                   : PGS
Codec ID                                 : 144
el_juan
Post by el_juan » Wed Mar 23, 2022 6:31 pm
Hi
I might be doing something wrong because when I use the tools that RESET_9999 has provided I get a smaller file size with the injected RPU than without.
I take a DV WEB-DL extract the .hevc file change the profile from 5 to 8 to get the RPU file, and then edit the active area in the RPU (no need to change the frames in this movie) then inject the newly generated RPU file in to the HDR10 REMUX .hevc file.
After that I take the HDR10 REMUX that has been made by another group and in mkvtoolnix I ONLY change the video part with the new injected .hevc.
But in the end the REMUX that only has HDR10 is still bigger than my HDR10 & DV version, can anyone explain this? The file has the same subs, audio formats and chapters.
Running the newest version of mkvmerge and dovi_tool
Example:
HDR: 49,3 GB (52.951.641.749 bytes)
HYBRiD: 49,2 GB (52.925.182.938 bytes)
Hope something can help me explain what i am doing wrong..
Post by RESET_9999 » Wed Mar 23, 2022 6:49 pm
Are you doing all of this manually? if yes, you don't have to. Just drag and drop your mkv/mp4 and let the script do everything.
I just checked Mode P5 to P8 no frame adj. / Workflow 2 (manual L5) and the filesize is as expected...
rosavanwinkle
Post by rosavanwinkle » Wed Mar 23, 2022 7:24 pm
Anyone by any chance has a profile 8.1 file test clip with truehd (6 channels) and dolby vision? they know that works on shield tv pro? either im doing something wrong in mkvtoolnix or my settings are wrong somewhere else cause the file only plays hdr10 when truehd is active,and dolby vision with ac3
i followed the video guide https://www.youtube.com/watch?v=hUAeltL62s8 he provided to the bone...
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Wed Mar 23, 2022 9:46 pm
I just tested my Shield and MKV/TS p8 + atmos file created by my script are working. Are you using mkvtoolnix or tsmuxer included in my tools pack?
yep because track #3 is not TrueHD. It will work in Version 1.1.3.
or you can test this code right now... just overwrite the bloc Workflow.1= P7 Bluray MPLS to P8 + DDP_1536kbps
 ::--------------------------------------------------------------------MODE.1.Workflow.1--------------------------------------------------------------------------------------------------------------------
:Workflow.1
::P7 Bluray MPLS to P8 + DDP_1536kbps
MD %output_path%TEMP\
set "TEMP=%output_path%TEMP\
echo -------------------------------------------------------------------------------------------------------------
echo --This workflow will convert a dual layer bluray MPLS to profile 8 and convert lossless audio to DD+ 1536kbps
 @echo off
 set /p BD_path=Drag and drop your BD folder and press enter...
cd C:\%UserInputPath%
%DGDemux_path% -d %BD_path%
set /p mpls_path=Drag and drop the main movie MPLS and press enter...
:: demux
%DGDemux_path% -i %mpls_path% -o %TEMP%
for %%f  in (%mpls_path%) do set "playlist.name_path=%%~nf
FOR /R %TEMP% %%G IN (*eng*.thd) do set "thd=%%~nG
FOR /R %TEMP% %%D IN (*eng*.dts) do set "dts=%%~nD
FOR /R %TEMP% %%B IN (*1011*.265) do set "BL=%%~nB
FOR /R %TEMP% %%E IN (*1015*.265) do set "EL=%%~nE
if exist "%TEMP%%thd:~0,33%.thd" rename "%TEMP%%thd:~0,34%.thd" "en.thd"
if exist "%TEMP%%dts:~0,43%.dts" rename "%TEMP%%dts:~0,43%.dts" "en.dts"
rename "%TEMP%%BL:~0,9%.265" "BL.hevc"
rename "%TEMP%%EL:~0,9%.265" "EL.hevc"
if exist %TEMP%en.thd goto :THD
if exist %TEMP%en.dts goto :DTS
:THD
%mkvmerge_path% --ui-language en --output ^"%TEMP%THD.mkv^" --audio-tracks 0 --language 0:en --compression 0:none ^"^(^" ^""%TEMP%en.thd"^" ^"^)^" --no-date
if exist %TEMP%en.thd goto :skip.dts
:DTS
:: encode first audio to DD+ 1536kbps
%mkvmerge_path% --ui-language en --output ^"%TEMP%THD.mkv^" --audio-tracks 0 --language 0:en --compression 0:none ^"^(^" ^""%TEMP%en.dts"^" ^"^)^" --no-date
:skip.dts
start %ffmpeg_path% -i %TEMP%THD.mkv -map 0:0 -c:a eac3 -b:a 1536k -c:s copy "%output_path%%playlist.name_path%_EC3.mkv"
:: extract/convert rpu %TEMP%RPU.bin  from %TEMP%Dolby-Vision-Tools\EL.hevc
%dovi_tool_path% -m 2 extract-rpu %TEMP%EL.hevc -o %TEMP%RPU.bin
if NOT ["%errorlevel%"]==["0"]  pause
:: inject %TEMP%RPU.bin into %TEMP%Dolby-Vision-Tools\BL.hevc and write %TEMP%P8.hevc
%dovi_tool_path% inject-rpu -i %TEMP%BL.hevc --rpu-in %TEMP%rpu.bin -o "%output_path%%playlist.name_path%_P8.hevc"
:: read rpu %TEMP%rpu.bin (frame 100)
%dovi_tool_path% info --input %TEMP%rpu.bin -f 100
:: delete temp files
rmdir /Q /S %TEMP%
echo "The script has completed."
if "%GUIpopup%"=="YES" goto :no.muxer
if "%mkvtoolnix.popup%"=="YES" goto :mkvtoolnix
if "%tsmuxer.popup%"=="YES" goto :tsmuxer
:tsmuxer
:: open tsmuxer GUI
%tsmuxer.GUI_path% "%output_path%%playlist.name_path%_P8.hevc" "%output_path%%playlist.name_path%_EC3.mkv" %mpls_path%
@pause & exit
:mkvtoolnix
%mkvtoolnix_path% "%output_path%%playlist.name_path%_P8.hevc" "%output_path%%playlist.name_path%_EC3.mkv" %mpls_path%
:no.muxer
@pause & exit
rosavanwinkle
Post by rosavanwinkle » Wed Mar 23, 2022 10:09 pm
RESET_9999 wrote:I just tested my Shield and MKV/TS p8 + atmos file created by my script are working. Are you using mkvtoolnix or tsmuxer included in my tools pack?
I followed the instructions like in the video, and then used mkvtoolmix from your app as suggested by you.
i created a mkv file with it
if you wish more info on my file i can give you that info, or just give you the files.
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Wed Mar 23, 2022 10:16 pm
yes PM the file and I'll test but it sounds like a problem with your system. Did you try other DV MKV + trueHD ?
el_juan
Post by el_juan » Wed Mar 23, 2022 10:24 pm
I have just tried with a new movie with the same result using the newest version DoVi_Scripts_1.1.2.
Active area was edited with 280 top and bottom.
Took the P8_DoVi.hevc and muxed with the hdr.mkv (removed the .hevc stream) with mkvmerge.
Edit:
When i removed the pgs subtitles from the HDR version and the P8_DoVi it seems to be correct.
Post by shawnc22 » Wed Mar 23, 2022 11:38 pm
The problem is your hardware. You either plug in your Shield directly to the TV to get DV and lose lossless audio, or you plug the Shield into your soundbar and lose DV. Your TV cannot passthrough lossless audio because it doesn't have eARC, and your soundbar doesn't support 4k passthrough. Unfortunately, you have to pick one or the other.
rosavanwinkle
Post by rosavanwinkle » Wed Mar 23, 2022 11:43 pm
that seems about right... unless i get myself a AVR...my soundbar only has 1.4 passthrough,i discussed this earlier a while back. so atm my setup is like this:
Shield -> tv
soundbar -> tv
it should be shield -> soundbar -> tv
but yeah sadly the hdmi is crap on both my tv and sound bar
either way i have uploaded a test file just in case so people can atleast test if i did it right for the people that have a perfect setup:
https://drive.google.com/file/d/1n4hYwb ... sp=sharing
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Thu Mar 24, 2022 12:08 am
Edit:
I just tested with a full movie with pgs subs instead of just a sample with video only, and the size is normal... so not sure what caused that on your end
Complete name                            : S:\Harry.Potter.and.the.Order.of.the.Phoenix.2007.P8_DoVi.mkv
File size                                : 54.0 GiB
Duration                                 : 2 h 18 min
Overall bit rate                         : 56.0 Mb/s
Writing application                      : mkvmerge v65.0.0 ('Too Much') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Video
Bit rate                                 : 49.1 Mb/s
Bits/(Pixel*Frame)                       : 0.247
Stream size                              : 47.4 GiB (88%)
Maximum Content Light Level              : 500 cd/m2
Maximum Frame-Average Light Level        : 200 cd/m2
Audio #1
Format                                   : DTS XLL X
Commercial name                          : DTS-HD Master Audio
Bit rate                                 : 3 953 kb/s
Channel(s)_Original                      : Object Based
ChannelLayout_Original                   : Object Based
Stream size                              : 3.82 GiB (7%)
Title                                    : Harry.Potter.and.the.Order.of.the.Phoenix.2007.2160p.BluRay.REMUX.HEVC.DTS-X.7.1-FGT
Audio #2
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Delay relative to video                  : 22 ms
Stream size                              : 190 MiB (0%)
Audio #3
Codec ID                                 : A_AC3
Stream size                              : 633 MiB (1%)
Language                                 : French
Audio #4
Codec ID                                 : A_AC3
Language                                 : Spanish
Audio #5
Codec ID                                 : A_AC3
Language                                 : Portuguese
Audio #6
Codec ID                                 : A_AC3
Language                                 : Japanese
Text #1
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 2 h 17 min
Bit rate                                 : 31.7 kb/s
Count of elements                        : 3046
Stream size                              : 31.2 MiB (0%)
Title                                    : English-PGS
Text #2
Format                                   : PGS
Bit rate                                 : 22.5 kb/s
Count of elements                        : 2742
Stream size                              : 22.1 MiB (0%)
Title                                    : French-PGS
Language                                 : French
Text #3
Format                                   : PGS
Bit rate                                 : 25.2 kb/s
Count of elements                        : 2574
Stream size                              : 24.8 MiB (0%)
Title                                    : Spanish-PGS
Language                                 : Spanish
Text #4
Format                                   : PGS
Bit rate                                 : 26.6 kb/s
Count of elements                        : 2620
Stream size                              : 26.2 MiB (0%)
Title                                    : Portuguese-PGS
Text #5
Format                                   : PGS
Duration                                 : 2 h 2 min
Bit rate                                 : 411 b/s
Count of elements                        : 34
Stream size                              : 369 KiB (0%)
Title                                    : French-PGS
Language                                 : French
Text #6
Format                                   : PGS
Bit rate                                 : 592 b/s
Count of elements                        : 48
Stream size                              : 531 KiB (0%)
Title                                    : Spanish-PGS
Language                                 : Spanish
Text #7
Format                                   : PGS
Bit rate                                 : 781 b/s
Count of elements                        : 52
Stream size                              : 701 KiB (0%)
Text #8
Format                                   : PGS
Duration                                 : 2 h 7 min
Bit rate                                 : 20.3 kb/s
Count of elements                        : 2853
Stream size                              : 18.5 MiB (0%)
Title                                    : Japanese-PGS
Language                                 : Japanese
Text #9
Format                                   : PGS
Duration                                 : 1 h 57 min
Bit rate                                 : 596 b/s
Count of elements                        : 313
Stream size                              : 513 KiB (0%)
Language                                 : Japanese
Menu
00:00:00.000                             : en:Chapter 1
00:04:50.832                             : en:Chapter 2
00:10:16.532                             : en:Chapter 3
00:15:19.877                             : en:Chapter 4
00:17:43.020                             : en:Chapter 5
00:20:52.209                             : en:Chapter 6
00:25:33.490                             : en:Chapter 7
00:28:07.143                             : en:Chapter 8
00:30:20.777                             : en:Chapter 9
00:34:53.758                             : en:Chapter 10
00:37:40.925                             : en:Chapter 11
00:41:48.297                             : en:Chapter 12
00:44:57.361                             : en:Chapter 13
00:50:57.220                             : en:Chapter 14
00:56:37.227                             : en:Chapter 15
01:03:28.471                             : en:Chapter 16
01:07:39.013                             : en:Chapter 17
01:11:15.854                             : en:Chapter 18
01:16:30.127                             : en:Chapter 19
01:19:16.460                             : en:Chapter 20
01:25:30.792                             : en:Chapter 21
01:31:30.526                             : en:Chapter 22
01:34:49.642                             : en:Chapter 23
01:37:42.273                             : en:Chapter 24
01:41:40.135                             : en:Chapter 25
01:45:59.102                             : en:Chapter 26
01:48:37.010                             : en:Chapter 27
01:52:40.754                             : en:Chapter 28
01:57:30.543                             : en:Chapter 29
02:03:32.988                             : en:Chapter 30
02:05:50.459                             : en:Chapter 31
02:08:26.865                             : en:Chapter 32
I just did a quick test with The Matrix 2022 BD to MP4 DD+ and subs and it worked on PLEX/C8 and shield... so perhaps going from P7 ST to P8 broke something.
but theres something i have to fix in the mp4 modes, the dd+ encoding doesnt have enough time to process and the mp4muxer try to start and fails. will fix in next version
General
Complete name                            : D:\other\DEMOS\TEST\00800_DoVi.sub.au.mp4
Format                                   : mp43
File size                                : 64.5 GiB
Duration                                 : 2 h 27 min
Overall bit rate                         : 62.4 Mb/s
Encoded date                             : UTC 2022-03-23 23:37:27
Tagged date                              : UTC 2022-03-23 23:37:27
Video
Bit rate                                 : 60.8 Mb/s
Bits/(Pixel*Frame)                       : 0.306
Stream size                              : 62.9 GiB (98%)
Encoded date                             : UTC 2022-03-23 23:23:24
Tagged date                              : UTC 2022-03-23 23:39:50
Maximum Content Light Level              : 1044 cd/m2
Maximum Frame-Average Light Level        : 648 cd/m2
Audio
Format                                   : E-AC-3
Codec ID                                 : ec-3
Stream size                              : 1.59 GiB (2%)
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 1 h 45 min
Bit rate                                 : 87 b/s
Stream size                              : 67.5 KiB (0%)
Encoded date                             : UTC 2022-03-23 23:39:50
yep
rosavanwinkle
Post by rosavanwinkle » Fri Mar 25, 2022 6:03 pm
Trying to get the script to work in ubuntu with wine,which seems like it launches etc. but it prepressed some buttons it seems every time i start it even though i havent pressed any yet
anyone has experience in running this in ubuntu?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
gacopl
Post by gacopl » Fri Mar 25, 2022 6:58 pm
comorla45 wrote:
Tue Mar 22, 2022 8:29 am
@gacopl I had no time to run your tool, so maybe you can answer me here. Does your scrip create MP4 that is hybrid format? I mean, DV+HDR10 compatible, so devices with no DV support will still run HDR10? Thanks.
It depends what is input if input is DV7 or DV8 then yes output is DV8.1 hdr10 compatible mp4. DV5 stays DV5 just in mp4 container that you can run on LG Oleds, Nvidia Shield not sure about other devices
