Need Help Flashing New Drive
mawaw
I just purchased an Archgon MD-8107S-U3YC blu ray drive and need help understanding how to flash the drive to play and rip 4K movies. Which firmware do I need to download for this drive and anything else I might need to know to do it.
Re: Need Help Flashing New Drive
BU40N 1.00 is the recommended firmware for your drive. See my signature for a premade flasher, so you can simply select your drive and press start to flash!mawaw wrote: Fri Mar 25, 2022 3:57 pm I just purchased an Archgon MD-8107S-U3YC blu ray drive and need help understanding how to flash the drive to play and rip 4K movies. Which firmware do I need to download for this drive and anything else I might need to know to do it.
mawaw
I downloaded the flasher tool and the firmware. When I select the firmware you mentioned and hit the Start button I get this error message: "Command produced error code 0x8f052603." Is there something I am doing wrong?
There are additional steps involved if you didn't want to read up on it buy his flashermawaw wrote: Sat Mar 26, 2022 1:49 pm I downloaded the flasher tool and the firmware. When I select the firmware you mentioned and hit the Start button I get this error message: "Command produced error code 0x8f052603." Is there something I am doing wrong?
mawaw
I read over the information but I am still having problems trying to flash the drive. The only steps I see is to 1. select the drive and then 2. select the firmware and then 3. make sure Write Firmware is selected. That is all I know to do unless I am missing some other steps. Please let me know.
mawaw
I finally was able to flash my drive to BU40N 1.00 but now I have a new problem. When I insert a 4K disc in the drive, after a few minutes to shows the name of the movie where it shows label but at the bottom I get these errors. Does anyone have a fix for this?
Thanks,
Mark
MakeMKV v1.16.7 win(x64-release) started
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '917504'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '948224'
udf: node fe/efe failed!
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '786432'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '821248'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '833536'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '806912'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/AACS/Content000.cer' at offset '0'
Thanks,
Mark
Make sure both usb plugs are plugged in to high powered USB ports.
Humble
Hey guys,
I am just starting out in building a plex server, but so far I am unable to rip any discs. I bought the LG BH16NS40 as I saw that it was one of the compatible drives, but it came with the v1.05 firmware. I have been going through the forms and I downloaded a flashing tool and some new firmware. I then flashed the drive with the WH16NS60 firmware but I started getting some errors.
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/AACS/Content000.cer' at offset '0'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '23283693568'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '32768'
Im trying to rip a blu-ray disc. The movie is Atomic Blonde. and the Protection is AACS v50
Any tips or tricks, or is the drive that I bought obsolete?
mawaw
Thanks. I had forgot to connect the 2nd USB cable. I was able to rip the first 4K DVD but each one since I am getting error codes. This is the last one I got.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '65536'
mawaw
I forgot to show the rest of the errors I got on the last dvd.
udf: UDF mount: reading in reserve VDS extent
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO3L91E5951' at offset '589824'
udf: udf mount: Metadata file not readable, substituting Metadata copy file
If you're experiencing rip errors, please read here first!
Uncorrectable error usually means the drive is having trouble reading a disc. Try gently cleaning the disc.
Did you open the tray while it was running?Humble wrote: Mon Mar 28, 2022 9:26 pm Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Humble
I opened the tray because my pc started to freeze up even though cpu was around 2%. I tried several times after that and the results were always the same even if i leave it for a hour.
Humble
I just got a proper line of errors.
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '131072'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '133120'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '135168'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '137216'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '139264'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '141312'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '143360'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '145408'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '147456'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '149504'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '151552'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '153600'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '155648'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '157696'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '159744'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQL8JF4212' at offset '161792'
udf: UDF mount: disc not properly formatted(bad VDS)
The files open in windows explorer but I still get these errors.
if the files open in explorer then they are not encrypted what type of disc is this not a retail UHD?Humble wrote: Mon Mar 28, 2022 10:45 pm I just got a proper line of errors.
makemkv is complaining about it not being formatted correctly and that could be the case if this is not a retail disc instead of the disc being physically messed up.
