ALERT ASUS BC-12D2HT New Firmware 3.11
DVD Maniac
#1 Post by DVD Maniac » Tue Nov 05, 2019 8:39 pm
Just got a new one of these. Others had 3.01 which all the usual tools were fine with. New batch received with 3.11 suddenly and cannot cross flash - Error # 4
Re: ALERT ASUS BC-12D2HT New Firmware 3.11
#2 Post by Billycar11 » Tue Nov 05, 2019 9:28 pm
DVD Maniac wrote: Tue Nov 05, 2019 8:39 pm Just got a new one of these. Others had 3.01 which all the usual tools were fine with. New batch received with 3.11 suddenly and cannot cross flash - Error # 4
See here https://www.makemkv.com/forum/viewtopic ... 16&t=19991
I have no idea how that works but multiple people say it does
#3 Post by MartyMcNuts » Tue Nov 05, 2019 10:56 pm
PM sent to DVD Maniac.
If anyone else has this model drive with 3.11, please do not try and flash it just yet. Please wait for further information.
DVD Maniac
#4 Post by DVD Maniac » Wed Nov 06, 2019 12:22 am
Problem solved! Thanks Marty you are a star. :D Understand you need to do more testing but it worked fine for me. Build is April 2019 - Taiwan now not China curiously
#5 Post by MartyMcNuts » Wed Nov 06, 2019 12:42 am
Good stuff @DVD Maniac!! Glad it works.
For anyone else wanting to downgrade your BC-12D2HT with firmware 3.11, please use the 3.11-MK firmware that Mike created from the dump I sent him. I've been waiting for Mike to update the MK pack with this firmware but he hasn't as yet.
At this stage, I don't know if this firmware is UHD friendly or not but you can flash to this 3.11-MK firmware, then flash to 3.01 if that is the end goal.
Firmware file attached below.
ASUS-BC-12D2HT-3.11-WM00300-211902271319.zip
(1.11 MiB) Downloaded 2077 times
If you use it, please let us know if it is "UHD friendly" or not....
Cheers!
#6 Post by d00zah » Wed Nov 06, 2019 1:23 am
Pretty sure re-enabling microcode access ("UHD friendly") is a hallmark of the 'MK' FWs, but I look forward to confirmation.
#7 Post by MartyMcNuts » Wed Nov 06, 2019 1:41 am
d00zah wrote: Wed Nov 06, 2019 1:23 am Pretty sure re-enabling microcode access ("UHD friendly") is a hallmark of the 'MK' FWs, but I look forward to confirmation.
MK firmware != UHD friendly.
I believe his goal was to enable microcode access so that basically drives would not be revoked with new MKB updates and that discs can be read in raw mode.
In saying that, we are fortunate that some (not all) MK firmwares have re-enabled UHD friendliness but this is not why Mike created them.
DVD Maniac
#8 Post by DVD Maniac » Wed Nov 06, 2019 6:30 pm
I can now confirm it works and not a one off, many thanks to Marty and Mike for their help. I have tested now with a second unit with troublesome titles like Mockingjay etc and all work perfectly. I have run some detailed drive tests and this new FW if retained in MK form performs MUCH better than the older ones. It gets pretty close to BW-16D1HT standards. Proves the point Mike has made that downgrading is not the way to go if you want optimal performance, Detailed test results will be posted shortly.
DVD Maniac
#9 Post by DVD Maniac » Wed Nov 06, 2019 10:15 pm
I think I have proof about downgrading. ASUS BW-16D1HT drive about 2 years old previously cross flashed with DosFlash with the much older FW''s and worked perfectly now is struggling with newer titles like the matrix UHD boxset. Spends ages booting it up with lots of jigger jiggering noises for about 2 minutes, eventually loads but refuses to play on any SW. Latest build April 2019 with MK cross flashed 3.10 no issues. Its a new disk, cleaned thoroughly and no scratches obviously. I would say that backs up Mike's advice 100%! :D
#10 Post by Billycar11 » Wed Nov 06, 2019 11:24 pm
DVD Maniac wrote: Wed Nov 06, 2019 10:15 pm I think I have proof about downgrading. ASUS BW-16D1HT drive about 2 years old previously cross flashed with DosFlash with the much older FW''s and worked perfectly now is struggling with newer titles like the matrix UHD boxset. Spends ages booting it up with lots of jigger jiggering noises for about 2 minutes, eventually loads but refuses to play on any SW. Latest build April 2019 with MK cross flashed 3.10 no issues. Its a new disk, cleaned thoroughly and no scratches obviously. I would say that backs up Mike's advice 100%! :D
Or maybe it's because it's 2 years old but on new asus's I use 3.10mk but on all other drives unless otherwise requested I use WH16NS60 1.00 except for bu40n I use 1.00 for that to.
Can you link me to Mike's advice I seem to have missed it.
DVD Maniac
#11 Post by DVD Maniac » Thu Nov 07, 2019 12:28 am
Hi Billy,
Yes thought occurred to me but have not had time to do it yet. Its still working fine except for newer titles. Thanks for confirming it works with MK 3.10 will try tomorrow. The post I am referring to is this one
#12 Post by Billycar11 » Thu Nov 07, 2019 3:39 am
DVD Maniac wrote: Thu Nov 07, 2019 12:28 am Hi Billy,
i see i did see that but that post was around before MK firmware was i thing back then i interpreted it as stop using dosflash and bricking drives lol because a lot of people wouldn't move there cal data over and the consequences were drive wont read disk no more.
i can see how it can be interpreted both was though
Thunderdome
#13 Post by Thunderdome » Fri Mar 25, 2022 12:21 pm
i flashed this a while ago,worked great!i hadnt used it in a while,tried this morningsetup as an external,but it wont open,it just sits with light flashing blue-any ideas?
#14 Post by Billycar11 » Fri Mar 25, 2022 12:30 pm
Thunderdome wrote: Fri Mar 25, 2022 12:21 pm i flashed this a while ago,worked great!i hadnt used it in a while,tried this morningsetup as an external,but it wont open,it just sits with light flashing blue-any ideas?
Does your external adapter support disc drive not all do
What the model of the adapter
Thunderdome
#15 Post by Thunderdome » Fri Mar 25, 2022 12:39 pm
i have tried on 2 drives ,they are the same drives,one from old system,i just unplugged to check other,now the one which was just 10 min ago,is same as other now,just a blue flashing light,tray wont open,pc isnt picking it up n ow either
## edit billy i used the fideco one on amazon 3.0 to sata
#pc now picks it up,but wont open tray,load disks,just idle flashing its blue light
UPDATE:Must have been a power issue,moved my plug and it cranked back to life-thanks for the replys :D
