LG BP60NB10 External Drive
strubdog
Post by strubdog » Fri Mar 25, 2022 1:42 am
So I'm upgrading from the Archgon MD-8107S-U3-UHD external drive to an LG BP60NB10 External Drive. The reason I'm upgrading is that the Archgon was causing circular scratches on my disc's from time to time.
What are people's experiences with the LG drive. Am I getting a good one or should I send it back to Amazon after I receive it?
Re: LG BP60NB10 External Drive
Post by MartyMcNuts » Fri Mar 25, 2022 3:17 am
strubdog wrote: Fri Mar 25, 2022 1:42 am So I'm upgrading from the Archgon MD-8107S-U3-UHD external drive to an LG BP60NB10 External Drive. The reason I'm upgrading is that the Archgon was causing circular scratches on my disc's from time to time.
Well, it's not really an upgrade as they are essentially the same hardware. The LG is in a plastic enclosure whereas the Archgon isn't. Give the LG a try and see how you go.
Make sure wherever you put the drive, it is level as I find circular scratches happen when the drive is running and it is not level.
strubdog
Post by strubdog » Fri Apr 01, 2022 8:45 pm
I just received my drive. It shows as having firmware version 1.02. Do I still need to flash this?
Post by d00zah » Fri Apr 01, 2022 8:55 pm
What does MakeMKV report in the Drive/LibreDrive info sections? You can copy/paste.
Post by MartyMcNuts » Fri Apr 01, 2022 9:56 pm
strubdog wrote: Fri Apr 01, 2022 8:45 pm I just received my drive. It shows as having firmware version 1.02. Do I still need to flash this?
Yes it had encrypted firmware and needs to be flashed.
strubdog
Post by strubdog » Wed Apr 06, 2022 10:53 pm
Can you point me to the specific post or firmware I should be using?
Post by Billycar11 » Thu Apr 07, 2022 12:58 am
strubdog wrote: Wed Apr 06, 2022 10:53 pm Can you point me to the specific post or firmware I should be using?
link below
strubdog
Post by strubdog » Thu Apr 07, 2022 4:22 am
I read the guide beforehand. Here is the entry I'm confused about:
"BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
BP60NB10 on any Firmware directly to > BP60NB10 1.02MK"
It looks like it references 2 different drives.
Post by MartyMcNuts » Thu Apr 07, 2022 4:35 am
strubdog wrote: Thu Apr 07, 2022 4:22 am I read the guide beforehand. Here is the entry I'm confused about:
It is 2 references for 2 drives. You have a BP60NB10 so you should only concern yourself with "BP60NB10 on any Firmware directly to > BP60NB10 1.02MK"
You said your's came with 1.02, so flash it to BP60NB10 1.02-MK and done! Start ripping.
strubdog
Post by strubdog » Thu Apr 07, 2022 5:12 am
Which thread has the link to this specific firmware?
strubdog
Post by strubdog » Thu Apr 07, 2022 5:30 am
Disregard, I was able to get it flashed.
corefunctions
Post by corefunctions » Wed Jan 15, 2025 8:03 am
I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
Post by MartyMcNuts » Wed Jan 15, 2025 11:06 pm
corefunctions wrote: Wed Jan 15, 2025 8:03 am I have this same drive but when I get to SDFtool the option to select a drive won’t even allow my drive to pop up. Any tips for that? And yes I have the drive plugged into laptop and yea my files for the flash are available to choose.
Install MakeMKV in the default location.
corefunctions
Post by corefunctions » Fri Jan 17, 2025 6:21 pm
MartyMcNuts wrote: Wed Jan 15, 2025 11:06 pm
I did install MKV on my mac but my Mac isn't able to open the SDFTool software. I tried using my friends PC to add the software. He doesn't have MKV downloaded on his PC.
Screenshot 2025-01-17 102026.png (16.48 KiB) Viewed 15802 times
Post by MartyMcNuts » Fri Jan 17, 2025 11:40 pm
corefunctions wrote: Fri Jan 17, 2025 6:21 pm
SDFTool Flasher is a Windows only frontend GUI for the MakeMKV command line. MakeMKV must be installed to use it.
