Encanto (Walmart Ultimate Collector's Edition)
AzurePanda
I've attempted to rip both the standard blu-ray and 4k UHD blu-ray copies that came with it. Neither disk will rip while both give the same combination of errors. I've included the log and if anyone can help that would be greatly appreciated. I swear Disney put some kind of voodoo hex on this disk! I keep getting a weird debug error code as well as 'OS error - STATUS_DEVICE_NOT_CONNECTED' but only for these disks. I literally ripped other regular and 4k disks before and after (had to unplug and reconnect the drive after the error). So it's not the drive as far as I can tell. I have no idea what is going on.
Re: Encanto (Walmart Ultimate Collector's Edition)
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO1L3VD2645' at offset '1376256'-
AzurePanda
I attempted again after plugging in both usb connectors which I have never had to do before. I didn't make it as far as before. While this time I didn't get the Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' error it usually occurred later in the process than I made it this time. I'm still getting a recurring DEBUG: Code 3221225664 at jy`8q}68o"jrtS*\:121267362. It repeats over and over and over and over until I close the program. I attached the log from this attempt as well. I hope someone can figure this out. I don't understand why it is just this single movie giving me these issues.
Debug log started at Wed Mar 23 06:44:46 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\f/MakeMKV_log.txt
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF v088: HL-DT-ST_BD-RE_BU40N_1.00_211612201528_MO1L3VD2645
001003:0020 DEBUG: Code 3221225653 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 3221225629 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 3221225629 at 3s}V)Ev#h<NJZ{[r)E:29395195
001003:0020 DEBUG: Code 3221225629 at 3s}V)Ev#h<NJZ{[r)E:29393792
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO1L3VD2645' at offset '3407872'-
All good advice really the only few things left if that are already using both USB cables is to clean the disc and laser and buy a high powered USB hub try the free options first.
Also replacing the discs is an option I don't know how these are packaged but many black hawk down disks were doa because they were packed disc on top of disc
AzurePanda
These weren't disc-on-disk in the packaging. I literally pulled the disks straight from sealed package to the drive, so they were pristine. I already used some air on the drive as well. As I said, every other disk I have, 4k and standard blu-ray, are scanning fine at this point (Only exception being the 4k of King's Man, but the standard worked fine). I'm guessing I'll have to replace the disks from a different retailer or something. I have no idea why this would make a difference since they both play fine. I have used a PS5 and a standalone blu-ray player to test both disks and they play flawlessly.
