How to Playback Blu-Rays?
papillon121
i have tried to playback Blu-Rays from my PC, but it doesent work. The Disc loads but no Playback.
Ive tried 2 different PCs, two different Blu-Ray Player (VERBATIM 43890 and Asus BC-12D2HT) and 2 different Software (VLC and MPV).
i do need the MPV Player to Playback cause of the dynamic tone mapping (cause home cinema).
Do anyone of you guys got an diea what i made wrong? This are normal Blu-Ray Discs, no UHD or something like this.
Re: How to Playback Blu-Rays?
Did you enable makemkv integration?papillon121 wrote: Wed Mar 23, 2022 11:28 am Hi,
Do you own makemkv it only works with licensed makemkv last time I tested
papillon121
i just want to playback the files, i dont wanna rip them or something.Billycar11 wrote: Wed Mar 23, 2022 12:04 pmDid you enable makemkv integration?papillon121 wrote: Wed Mar 23, 2022 11:28 am Hi,
Yes that's why my questions are relevantpapillon121 wrote: Wed Mar 23, 2022 12:13 pmi just want to playback the files, i dont wanna rip them or something.Billycar11 wrote: Wed Mar 23, 2022 12:04 pmDid you enable makemkv integration?papillon121 wrote: Wed Mar 23, 2022 11:28 am Hi,
papillon121
how can i enable makemkv in MPV Player? i dont have a lincensed makemkv but i would buy one if it would work.Billycar11 wrote: Wed Mar 23, 2022 12:17 pmYes that's why my questions are relevantpapillon121 wrote: Wed Mar 23, 2022 12:13 pmi just want to playback the files, i dont wanna rip them or something.Billycar11 wrote: Wed Mar 23, 2022 12:04 pm
Makemkv- preferences - integration - enable it for your program.
But you need to buy makemkv unless that has changed try it first I guess but you should buy makemkv it's great
papillon121
i got the message that i can test makemkv for 30 days and then i need to buy it.Billycar11 wrote: Wed Mar 23, 2022 12:37 pm Makemkv- preferences - integration - enable it for your program.
i enabled the section, but nothing happened, still it will not play. or do i need to do more after enabling it?
I've never successfully played a disc with MPV, although I have with VLC.
I'm pretty sure @Billycar11 is right… disc playback only works with a payed-for version of MakeMKV.
papillon121
so it doesent work with the free trail? is there any tutorial to playback BluRays with makemkv and MPV Player?dcoke22 wrote: Wed Mar 23, 2022 2:53 pm I've never successfully played a disc with MPV, although I have with VLC.
Out of curiosity, are you trying to playback a regular blu-ray or a 4K UHD blu-ray that has HDR or perhaps Dolby Vision?papillon121 wrote: Wed Mar 23, 2022 11:28 am i do need the MPV Player to Playback cause of the dynamic tone mapping (cause home cinema).
papillon121
i just want to playback a normal Blu-Ray, without any UHD or such things...dcoke22 wrote: Wed Mar 23, 2022 6:13 pmOut of curiosity, are you trying to playback a regular blu-ray or a 4K UHD blu-ray that has HDR or perhaps Dolby Vision?papillon121 wrote: Wed Mar 23, 2022 11:28 am i do need the MPV Player to Playback cause of the dynamic tone mapping (cause home cinema).
Then why does it have to be MPV? In your first post you said dynamic tone mapping, but I'm only aware of that being import for things with HDR or Dolby Vision and I'm only aware of that being on UHDs. Do you have a regular blu-ray with something like that? Maybe it is something else MPV does that VLC does not?papillon121 wrote: Wed Mar 23, 2022 7:29 pm i just want to playback a normal Blu-Ray, without any UHD or such things...
papillon121
I got a Homecinema and ive tested VLC VS MPV, in an german forum we created a perfect setting with dynamic tonemapping for MPV. But, by the way, VLC doesent work too...dcoke22 wrote: Wed Mar 23, 2022 7:52 pmThen why does it have to be MPV? In your first post you said dynamic tone mapping, but I'm only aware of that being import for things with HDR or Dolby Vision and I'm only aware of that being on UHDs. Do you have a regular blu-ray with something like that? Maybe it is something else MPV does that VLC does not?papillon121 wrote: Wed Mar 23, 2022 7:29 pm i just want to playback a normal Blu-Ray, without any UHD or such things...
- 39276d83-2939-4d68-a80d-8cfb32767c0d.jpg (212.77 KiB) Viewed 23297 times
boolian2
Do yourself a favor and get a Zidoo box.
donpimp
Your theater is dope! Remember all those media players like VLC won't play until you first get AACS figured out and obtain keys
