the video is a profile 7 to profile 8.1 conversion
i accidently closed tsmuxer after it was done in the CMD with your script
is this the right settings to convert after its done with the cmd stuff? or do i change anything else?
https://i.imgur.com/vKUgq1Z.png
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
it doesnt matter if you close tsmuxer without muxing. the P8 file is still in your output folder.rosavanwinkle wrote: ↑Tue Mar 22, 2022 12:27 ami accidently closed tsmuxer after it was done in the CMD with your script
But since you're using a shield, you should edit the bat file and change the muxer to mkvtoolnix.
The web-dl I have needs a cut at the beginning to match the length of the UHD BD but I haven’t had time to work out how much to cut and how best to do it.RESET_9999 wrote: ↑Mon Mar 21, 2022 2:18 pmAh I didnt know there was another p5 web-dl version. Then yes you have to edit L5.jayper wrote: ↑Mon Mar 21, 2022 2:13 pmI appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
I am still a bit confused... Perhaps I'm misinterpreting things, but the version I have is cropped, meaning there are no black bars in the web-dl. The resolution is 3840x1606. I just demuxed it again and extracted the RPU, and when reading the RPU there is L5 section and no active area offsets. Perhaps I am missing something, or I got a bad release? Thanks again.
the webdl i was talking about:
Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.2@Main HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 2 h 36 min Bit rate : 23.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 0) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.117 Stream size : 25.3 GiB (97%) Default : Yes Alternate group : 1 Encoded date : UTC 2022-03-02 18:06:45 Tagged date : UTC 2022-03-02 18:13:15 Color range : Full Codec configuration box : hvcC+dvcC
@gacopl I had no time to run your tool, so maybe you can answer me here. Does your scrip create MP4 that is hybrid format? I mean, DV+HDR10 compatible, so devices with no DV support will still run HDR10? Thanks.
Your tool worked perfect in combination with your video thank you very much.
i do have one question that might be a hardware issue or setting on my end i messed up
playing the movie with truehd will not activate the dolby vision,it goes to hdr,but when i select the ac-3 audio layer it will use dolby vision
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Open both the web-dl and the HDR10 mkv (made with MakeMKV) in StaxRip. Then preview both versions of the film. Find the exact same frame in the film, in both files, and note which number of the frame it is frame for each version. If the web-dl is longer, subtract the total frames from the UHD/mkv from the total frames of the web-dl. Write this number down. You will use this number to remove frames from the web-dl, but note, that frame removal is inclusive so you must enter the number that is one less than the frame difference you calculated. So, if for example: [Frame number of web-dl] - [Frame number of UHD/mkv] = difference in frames. Then you take this number and subtract one.DaMacFunkin wrote: ↑Tue Mar 22, 2022 5:58 amThe web-dl I have needs a cut at the beginning to match the length of the UHD BD but I haven’t had time to work out how much to cut and how best to do it.RESET_9999 wrote: ↑Mon Mar 21, 2022 2:18 pmAh I didnt know there was another p5 web-dl version. Then yes you have to edit L5.jayper wrote: ↑Mon Mar 21, 2022 2:13 pmI appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
There was a tutorial video that was shared that outlined the process, check it out here: https://drive.google.com/drive/u/0/fold ... nKkuCEGqg4
Please note, in that video, frames are being ADDED. Your process will be roughly the same, except you will be choosing to add frames rather than remove them.
I don't know... what container did you use? shield? which app...rosavanwinkle wrote: ↑Tue Mar 22, 2022 11:42 amYour tool worked perfect in combination with your video thank you very much.
last time I checked, MKV DV + TrueHD works on PLEX/Shield.
I'll redo that video because it is outdated and there is an error in it... I treated the frame duplication as inclusive when it's not. Only the frames removal is inclusive.jayper wrote: ↑Tue Mar 22, 2022 2:23 pmThere was a tutorial video that was shared that outlined the process, check it out here: https://drive.google.com/drive/u/0/fold ... nKkuCEGqg4
i use the plex app straight from the android store,server is on a seedbox but even on my normal pc plex server it uses hdr with truehd,maybe its a setting i wronged in either mkvtoolnix,plex server settings/plex player settingsRESET_9999 wrote: ↑Tue Mar 22, 2022 4:16 pmI don't know... what container did you use? shield? which app...rosavanwinkle wrote: ↑Tue Mar 22, 2022 11:42 amYour tool worked perfect in combination with your video thank you very much.
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Hello, I've been trying to use @RESET_9999 's script to convert a P7 DT-DL Blu Ray (Game of Thrones new DV BD set) into P8 + DDP_1536kbps with this option. Thing is, I think it's failing because the files have their #1 audio track as DD and the #2 one as THD w/ Atmos, instead of being the other way around. Here's a snap of from mediainfo.
Now, I think in order to fix this I would just need to swap around the track number that the script points to. But I don't really know what exactly it is I need to change, although I've figured it must be somewhere in this part.
Could anyone give me a hand with this?
Also wanted to check if this would be the easiest way to convert these files in order to play them with DV on the Plex app of my LG C1 OLED.
Yes, my script expects a TrueHD audio as track number 3 and it doesnt even work with the DTS fam . I will add more audio support eventually.Obliver wrote: ↑Wed Mar 23, 2022 12:07 amHello, I've been trying to use @RESET_9999 's script to convert a P7 DT-DL Blu Ray (Game of Thrones new DV BD set) into P8 + DDP_1536kbps with this option. Thing is, I think it's failing because the files have their #1 audio track as DD and the #2 one as THD w/ Atmos, instead of being the other way around. Here's a snap of from mediainfo.
Because the script use tsmuxer to demux bluray disc , it's a bit tricky to make the change here. I'm looking at maybe switching to DGdemux.
You could rip all the episodes to MKV P7 + atmos and then use the "Workflow.2= P7 ST-DL to P8 + DDP_1536kbps"
Yep, P8 + DDP 1536kbps is the way to go on LG OLED TVs
For our convenience, Rocky has built thdmerge into latest DGDemux 1.0.0.60. After demux you'll have gap-processed thd, ac3 and thd+ac3 tracks. It obviously hasn't the "Do not split THD" option anymore. Gap-processed THD+AC3 is not a one-pass run; after having gap-processed and demuxing the elementary streams, during a second run the ac3 and thd will be interleaved.
Of course the cli tool thdmerge.exe will still be at our disposal for manually interleaving any ac3 with thd. Which latest version you'll find in the DGDemux download.
http://rationalqm.us/dgdemux/binaries/
I’ve tried this as per the video but I get the error invalid MKV, no other information. The p7 is muxed by makemkv from the UHD and the P5 is a d I s n e y Webdl.RESET_9999 wrote: ↑Tue Mar 22, 2022 4:16 pmI don't know... what container did you use? shield? which app...rosavanwinkle wrote: ↑Tue Mar 22, 2022 11:42 amYour tool worked perfect in combination with your video thank you very much.
Is there a detailed log I can produce?
Thank you.
Which workflow exactly ? there could be a typo.DaMacFunkin wrote: ↑Wed Mar 23, 2022 4:21 pmI’ve tried this as per the video but I get the error invalid MKV, no other information. The p7 is muxed by makemkv from the UHD and the P5 is a d I s n e y Webdl.
Thank you.
Also, if you select a workflow that converts THD and your mkv doesn't contain THD, it will fail.
but why do you want to inject DV if your bluray remux is P7 ?
I've tried going from a DT-DL Bluray MPLS to MP4 P8 DDP 1536 kbps but Plex app won't recognize it. Workflow is DT-DL Bluray > HEVC P7 SL DL (yuseope) > MKV mux P7 ST DL with Atmos THD > MP4 P8 with DDP 1536 kbps.
This is the end file:
Does it have to do with the dvhe codec? The following file from the same initial BD with hev1 codec gets recognized fine by Plex:
How can I get Plex to recognize them? T_T
Or at least is there a script to go from that Bluray DT-DL to the MP4 with hev1 codec that's recognized by Plex?
General
Complete name : P:\Test\00800_ST-DL_DoVi.sub.au.mp4
Format : mp43
Codec ID : mp43 (isom/mp43/dby1)
File size : 23.0 GiB
Duration : 1 h 1 min
Overall bit rate mode : Variable
Overall bit rate : 53.3 Mb/s
Encoded date : UTC 2022-03-23 15:43:39
Tagged date : UTC 2022-03-23 15:43:39
Writing application : GPAC-1.1.0-DEV-rev1027-g1daa0b5f-master
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Bit rate : 51.8 Mb/s
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.260
Stream size : 22.3 GiB (97%)
Default : No
Encoded date : UTC 2022-03-23 15:32:04
Tagged date : UTC 2022-03-23 15:53:06
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Maximum bit rate : 1 622 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 62.500 FPS (768 SPF)
Compression mode : Lossy
Stream size : 678 MiB (3%)
Service kind : Complete Main
Default : No
Text
Format : Timed Text
Codec ID : tx3g
Duration : 1 h 0 min
Bit rate mode : Variable
Bit rate : 44 b/s
Stream size : 19.3 KiB (0%)
Title : srt@GPAC1.1.0-DEV-rev1027-g1daa0b5f-master
Forced : No
Encoded date : UTC 2022-03-23 15:53:06
General
Complete name : P:\Backup\S01E01 - Winter is Coming.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 22.6 GiB
Overall bit rate : 52.4 Mb/s
Encoded date : UTC 2022-03-09 05:28:08
Tagged date : UTC 2022-03-09 05:28:08
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Stream size : 22.3 GiB (99%)
Default : Yes
Alternate group : 1
Codec configuration box : hvcC+dvvC
Audio
Format : E-AC-3
Codec ID : ec-3
Bit rate : 640 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 282 MiB (1%)
Language : English
Default : Yes
Alternate group : 2
