rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 12:45 pm
RESET_9999 wrote: Mon Mar 21, 2022 12:29 pm you don't need tsmuxer for the Shield. Use Mkvtoolnix or makemkv
rosavanwinkle wrote: Mon Mar 21, 2022 11:35 am thanks for the info great help.
i went to get the specific tsmuxer that yuescope linked us but euhm the link shows me to a strange website without any download
thanks again for that info,will version 53 of mkvtoolnix work? last time i checked it did i think... its because i have a seedbox and they cant ugprade it atm beyond version 53 :/
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
jayper
Post by jayper » Mon Mar 21, 2022 2:13 pm
RESET_9999 wrote: Mon Mar 21, 2022 11:21 am
jayper wrote: Mon Mar 21, 2022 4:29 am Has anyone done a P5 to BD remux for West Side Story? I am measuring the top and bottom L5 areas and I have checked it 5 different times. My eyes may be deceiving me, but I am not getting equal numbers for the top and bottom areas.
Measuring 280 for the top and 276 for the bottom. Am I losing it?
the dv web-dl is not cropped so it probably already has proper L5.
you only have to edit L5 when the web-dl is cropped.
I dont have this movie remux but if i look at the scene encode, it's 1608px so 276/276
I appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
I am still a bit confused... Perhaps I'm misinterpreting things, but the version I have is cropped, meaning there are no black bars in the web-dl. The resolution is 3840x1606. I just demuxed it again and extracted the RPU, and when reading the RPU there is L5 section and no active area offsets. Perhaps I am missing something, or I got a bad release? Thanks again.
Post by RESET_9999 » Mon Mar 21, 2022 2:18 pm
jayper wrote: Mon Mar 21, 2022 2:13 pm I appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
Ah I didnt know there was another p5 web-dl version. Then yes you have to edit L5.
the webdl i was talking about:
Format : HEVC
Format profile : Main 10@L5.2@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 2 h 36 min
Bit rate : 23.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.117
Stream size : 25.3 GiB (97%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2022-03-02 18:06:45
Tagged date : UTC 2022-03-02 18:13:15
Color range : Full
Codec configuration box : hvcC+dvcC
jayper
Post by jayper » Mon Mar 21, 2022 2:37 pm
RESET_9999 wrote: Mon Mar 21, 2022 2:18 pm Ah I didnt know there was another p5 web-dl version. Then yes you have to edit L5.
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Color range : Full
Ah, ok thanks! I will look around for a different version just to make things simpler. What happens if you don't edit the L5 active area? Will the black letterbox bars be off color or grey?
Post by RESET_9999 » Mon Mar 21, 2022 2:40 pm
jayper wrote: Mon Mar 21, 2022 2:37 pm Ah, ok thanks! I will look around for a different version just to make things simpler. What happens if you don't edit the L5 active area? Will the black letterbox bars be off color or grey?
It could cause some visual defect as @Quietvoid explained recently.
Printdivision
Post by Printdivision » Mon Mar 21, 2022 6:55 pm
Hi, I'm new here and I want to tell you that I really appreciate what you're doing here. I have a big problem with some BDMV files (few, but very important), Gladiator, Braveheart, Interstellar, Saving private Ryan. I run them on the UBP-X800M2 on USB and for information, the running time is 0.00.00, why? , can't scroll back and forth, why? I passed them through tsMuxeR (M2TS), for Dolby Vision and nothing, they behave the same, what can I do, they can be solved? Thanks for any suggestions.
rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 7:29 pm
so the command that im using in ffmpeg is not working....
it creates like a really small file and lots of errors in my cmd
this is my command based on the uhd to profile 8.1 for dual track dv files:
ffmpeg -i "F:\conversion\The.Godfather.1972.2160p.BluRay.HEVC.TrueHD.5.1-ESiR[IPT]\BDMV\STREAM\00005.m2ts" -ss 0 -t 120 -map 0:0 -c copy "F:\conversion\exit\BL.hevc"
the original:
ffmpeg -i path\to\the\file.m2ts -ss 0 -t 120 -map 0:0 -c copy path\to\BL.hevc
the cmd output
https://pastebin.com/DpZ7iJG4
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Mon Mar 21, 2022 9:57 pm
rosavanwinkle wrote: Mon Mar 21, 2022 7:29 pm so the command that im using in ffmpeg is not working....
Do as @Gatorman suggested and use my script...
everything is automated, you don't have to mess with cmd-lines anymore:
https://www.youtube.com/watch?v=hUAeltL62s8
rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 9:58 pm
RESET_9999 wrote: Mon Mar 21, 2022 9:57 pm
does this also work for profile 8.1?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Mon Mar 21, 2022 10:14 pm
rosavanwinkle wrote: Mon Mar 21, 2022 9:58 pm
the video is a profile 7 to profile 8.1 conversion
rosavanwinkle
Post by rosavanwinkle » Tue Mar 22, 2022 12:27 am
i accidently closed tsmuxer after it was done in the CMD with your script
is this the right settings to convert after its done with the cmd stuff? or do i change anything else?
https://i.imgur.com/vKUgq1Z.png
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Tue Mar 22, 2022 12:31 am
rosavanwinkle wrote: Tue Mar 22, 2022 12:27 am i accidently closed tsmuxer after it was done in the CMD with your script
it doesnt matter if you close tsmuxer without muxing. the P8 file is still in your output folder.
But since you're using a shield, you should edit the bat file and change the muxer to mkvtoolnix.
DaMacFunkin
Post by DaMacFunkin » Tue Mar 22, 2022 5:58 am
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Color range : Full
The web-dl I have needs a cut at the beginning to match the length of the UHD BD but I haven’t had time to work out how much to cut and how best to do it.
comorla45
Post by comorla45 » Tue Mar 22, 2022 8:29 am
@gacopl I had no time to run your tool, so maybe you can answer me here. Does your scrip create MP4 that is hybrid format? I mean, DV+HDR10 compatible, so devices with no DV support will still run HDR10? Thanks.
rosavanwinkle
Post by rosavanwinkle » Tue Mar 22, 2022 11:42 am
Your tool worked perfect in combination with your video thank you very much.
i do have one question that might be a hardware issue or setting on my end i messed up
playing the movie with truehd will not activate the dolby vision,it goes to hdr,but when i select the ac-3 audio layer it will use dolby vision
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
