rosavanwinkle
Post by rosavanwinkle »
My god this thread is still going even after maybe 2 years of being inactive on it...
so if i wanna convert my raw blueray files with dolby vision to a single layer what is the best use atm?
It is for use on a shield tv pro with plex and a LG tv
i used to use yuescope tool,but is their something else out their now or something better?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Gatorman
Post by Gatorman »
rosavanwinkle wrote:
Sun Mar 20, 2022 5:19 pm
Checkout the links within the signature of RESET_9999's post above yours.
More reasons to collect physical media. 2019 Shield TV Pro.
jayper
Post by jayper »
Has anyone done a P5 to BD remux for West Side Story? I am measuring the top and bottom L5 areas and I have checked it 5 different times. My eyes may be deceiving me, but I am not getting equal numbers for the top and bottom areas.
Measuring 280 for the top and 276 for the bottom. Am I losing it?
jayper wrote:
Mon Mar 21, 2022 4:29 am
the dv web-dl is not cropped so it probably already has proper L5.
you only have to edit L5 when the web-dl is cropped.
I dont have this movie remux but if i look at the scene encode, it's 1608px so 276/276
rosavanwinkle
Gatorman wrote:
Mon Mar 21, 2022 12:14 am
thanks for the info great help.
i went to get the specific tsmuxer that yuescope linked us but euhm the link shows me to a strange website without any download
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
you don't need tsmuxer for the Shield. Use Mkvtoolnix or makemkv
Mon Mar 21, 2022 11:35 am
rosavanwinkle
RESET_9999 wrote:
Mon Mar 21, 2022 12:29 pm
thanks again for that info,will version 53 of mkvtoolnix work? last time i checked it did i think... its because i have a seedbox and they cant ugprade it atm beyond version 53 :/
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
jayper
Post by jayper »
RESET_9999 wrote:
Mon Mar 21, 2022 11:21 am
I appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
I am still a bit confused... Perhaps I'm misinterpreting things, but the version I have is cropped, meaning there are no black bars in the web-dl. The resolution is 3840x1606. I just demuxed it again and extracted the RPU, and when reading the RPU there is L5 section and no active area offsets. Perhaps I am missing something, or I got a bad release? Thanks again.
jayper wrote:
Mon Mar 21, 2022 2:13 pm
Ah I didnt know there was another p5 web-dl version. Then yes you have to edit L5.
the webdl i was talking about:
Format : HEVC
Format profile : Main 10@L5.2@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 2 h 36 min
Bit rate : 23.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.117
Stream size : 25.3 GiB (97%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2022-03-02 18:06:45
Tagged date : UTC 2022-03-02 18:13:15
Color range : Full
Codec configuration box : hvcC+dvcC
jayper
Post by jayper »
RESET_9999 wrote:
Mon Mar 21, 2022 2:18 pm
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Color range : Full
Ah, ok thanks! I will look around for a different version just to make things simpler. What happens if you don't edit the L5 active area? Will the black letterbox bars be off color or grey?
jayper wrote:
Mon Mar 21, 2022 2:37 pm
It could cause some visual defect as @Quietvoid explained recently.
Printdivision
Post by Printdivision »
Hi, I'm new here and I want to tell you that I really appreciate what you're doing here. I have a big problem with some BDMV files (few, but very important), Gladiator, Braveheart, Interstellar, Saving private Ryan. I run them on the UBP-X800M2 on USB and for information, the running time is 0.00.00, why? , can't scroll back and forth, why? I passed them through tsMuxeR (M2TS), for Dolby Vision and nothing, they behave the same, what can I do, they can be solved? Thanks for any suggestions.
rosavanwinkle
so the command that im using in ffmpeg is not working....
it creates like a really small file and lots of errors in my cmd
this is my command based on the uhd to profile 8.1 for dual track dv files:
ffmpeg -i "F:\conversion\The.Godfather.1972.2160p.BluRay.HEVC.TrueHD.5.1-ESiR[IPT]\BDMV\STREAM\00005.m2ts" -ss 0 -t 120 -map 0:0 -c copy "F:\conversion\exit\BL.hevc"
the original:
ffmpeg -i path\to\the\file.m2ts -ss 0 -t 120 -map 0:0 -c copy path\to\BL.hevc
the cmd output
https://pastebin.com/DpZ7iJG4
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Mon Mar 21, 2022 7:29 pm
Do as @Gatorman suggested and use my script...
everything is automated, you don't have to mess with cmd-lines anymore:
https://www.youtube.com/watch?v=hUAeltL62s8
rosavanwinkle
RESET_9999 wrote:
Mon Mar 21, 2022 9:57 pm
does this also work for profile 8.1?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
