when you manually edit L5. You enter just 260...Gatorman wrote: ↑Sun Mar 20, 2022 5:56 am@RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
in manual modes, it only edit top/bottom which means if your video has right and left borders, you have to use the AUTO-L5 workflows.
The new version that I'll upload today will include:
- Support input files with space and special characters
- New workflows that fix invalid L6 metadata in some p5 web-dl (> 10 000)
- New workflows that can remove HDR10plus when injecting DV ( for the firestick TV)
- Now the output filename will be the input filename instead of just " P8.hevc"
