Am I the only one that can't save settings?
Everytime I either try to set the default directory or the minimum title length it errors and says "Failed to save settings" then "Some settings will apply next time you start the application". If I exit, everything is back to the defaults. However, if I use it before I exit, all the settings stay except for default directory. Any idea?
Re: Am I the only one that can't save settings?
Anyone? DASPI mode has basically hosed my ripping capability so I'd like to revert to 1.6.3. However, because I can't save any settings when I enter the key I got when I bought it, it won't register and then I can't load the program.
- Contact:
If you just disable DASPI then 1.6.5 should work as good as 1.6.3 . The settings are saved in file ~/.MakeMKV/settings.conf - check permissions or delete the file if needed.
Mike, no matter what I do, I cannot save my settings for some reason. As soon as I change anything in preferences it says "Failed to Save settings". I then click ok and get another dialog that says "Some settings will apply next time you start the application". The settings will stick while I have the app loaded, but as soon as I restart it, it has forgotten again. I can't even put in my key I bought.
- Contact:
Please run terminal and post the output of
either here or via PM
id
ls -la ~
ls -la ~/.MakeMKV
