Post by MartyMcNuts » Tue Mar 15, 2022 11:26 pm
RESET_9999 wrote:
Mon Mar 07, 2022 8:10 pm
ArArdin wrote:
Mon Mar 07, 2022 5:29 pm
RESET_9999 wrote:
Mon Mar 07, 2022 12:13 pm
I guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
Yes, I'd think so too. Thinking of this new option, any other track that's on the disc? For example, a commentary track you really like?
I couldnt make a 32kbps track and thdmerge would not process a 40kbps track but it seems to work at 64kbps. Hopefully, the track still play on my x800m2
here's 4h of silent 5.1 AC3 audio at 64kbps.
https://drive.google.com/file/d/19n0b_0 ... sp=sharing
EDIT: it works on the x800m2 !!!!!
Why not just create a 64kbps or 128kbps ac3 track from the original audio? Or use the core ac3?
Post by RESET_9999 » Wed Mar 16, 2022 12:31 am
that would require encoding. With the 4h silent track, I can use it for any movie without having to re-encode.
mehgh750
Post by mehgh750 » Wed Mar 16, 2022 6:07 am
The provided link for 4h of silent ac3 audion doesn't work:
Can you please share it again?
gacopl
Post by gacopl » Wed Mar 16, 2022 1:12 pm
comorla45 wrote:
Sun Mar 13, 2022 8:13 pm
@gacopl would it be possible for you to make this script for windows powershell/cmd? I was looking for just that, as I use plex on LG B1/C1 and other devices, so AC3/EAC3 is a must for direct stream with subtitles (LG).
Nope I am Linux guy and I think there are tools for windows already. Anyways you should be able to use it with WSL2
gacopl
Post by gacopl » Wed Mar 16, 2022 1:14 pm
Snickers333 wrote:
Mon Mar 14, 2022 1:03 pm
Guys i have run into a problem running this script.
https://github.com/gacopl/dvmkv2mp4
I tried to troubleshoot it myself but with no luck. Anyone run into this issue as well ?
Trying to convert Profile 7 BL_RPU_EL single track mkv to mp4
That error comes from newest mp4box you need to have version 1.0.1 installed then it will be fine
gacopl
Post by gacopl » Wed Mar 16, 2022 3:30 pm
Albano wrote:
Fri Mar 11, 2022 8:57 pm
Tell me how to setup and run your script.
I've download it to my PC, but I cannot run it.
This is for linux not windows it's meant to be put on your mediaserver/NAS whatever, follow the steps from README to install all needed stuff
You can also run it in virtual machine with linux
Post by RESET_9999 » Wed Mar 16, 2022 4:13 pm
https://drive.google.com/file/d/1S2_aDy ... sp=sharing
Gatorman
Post by Gatorman » Sun Mar 20, 2022 5:56 am
@RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
Post by RESET_9999 » Sun Mar 20, 2022 12:59 pm
when you manually edit L5. You enter just 260...
in manual modes, it only edit top/bottom which means if your video has right and left borders, you have to use the AUTO-L5 workflows.
The new version that I'll upload today will include:
- Support input files with space and special characters
- New workflows that fix invalid L6 metadata in some p5 web-dl (> 10 000)
- New workflows that can remove HDR10plus when injecting DV ( for the firestick TV)
- Now the output filename will be the input filename instead of just " P8.hevc"
rosavanwinkle
Post by rosavanwinkle » Sun Mar 20, 2022 5:19 pm
My god this thread is still going even after maybe 2 years of being inactive on it...
so if i wanna convert my raw blueray files with dolby vision to a single layer what is the best use atm?
It is for use on a shield tv pro with plex and a LG tv
i used to use yuescope tool,but is their something else out their now or something better?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Gatorman
Post by Gatorman » Mon Mar 21, 2022 12:14 am
Checkout the links within the signature of RESET_9999's post above yours.
jayper
Post by jayper » Mon Mar 21, 2022 4:29 am
Has anyone done a P5 to BD remux for West Side Story? I am measuring the top and bottom L5 areas and I have checked it 5 different times. My eyes may be deceiving me, but I am not getting equal numbers for the top and bottom areas.
Measuring 280 for the top and 276 for the bottom. Am I losing it?
Post by RESET_9999 » Mon Mar 21, 2022 11:21 am
the dv web-dl is not cropped so it probably already has proper L5.
you only have to edit L5 when the web-dl is cropped.
I dont have this movie remux but if i look at the scene encode, it's 1608px so 276/276
rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 11:35 am
thanks for the info great help.
i went to get the specific tsmuxer that yuescope linked us but euhm the link shows me to a strange website without any download
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Mon Mar 21, 2022 12:29 pm
you don't need tsmuxer for the Shield. Use Mkvtoolnix or makemkv
