gacopl
Post by gacopl » Wed Mar 16, 2022 1:12 pm
comorla45 wrote: Sun Mar 13, 2022 8:13 pm
@gacopl would it be possible for you to make this script for windows powershell/cmd? I was looking for just that, as I use plex on LG B1/C1 and other devices, so AC3/EAC3 is a must for direct stream with subtitles (LG).
Nope I am Linux guy and I think there are tools for windows already. Anyways you should be able to use it with WSL2
gacopl
Post by gacopl » Wed Mar 16, 2022 1:14 pm
Snickers333 wrote: Mon Mar 14, 2022 1:03 pm Image
Guys i have run into a problem running this script.
https://github.com/gacopl/dvmkv2mp4
I tried to troubleshoot it myself but with no luck. Anyone run into this issue as well ?
Trying to convert Profile 7 BL_RPU_EL single track mkv to mp4
That error comes from newest mp4box you need to have version 1.0.1 installed then it will be fine
gacopl
Post by gacopl » Wed Mar 16, 2022 3:30 pm
Albano wrote: Fri Mar 11, 2022 8:57 pm Tell me how to setup and run your script.
I've download it to my PC, but I cannot run it.
This is for linux not windows it's meant to be put on your mediaserver/NAS whatever, follow the steps from README to install all needed stuff
You can also run it in virtual machine with linux
Post by RESET_9999 » Wed Mar 16, 2022 4:13 pm
mehgh750 wrote: Wed Mar 16, 2022 6:07 am Can you please share it again?
https://drive.google.com/file/d/1S2_aDy ... sp=sharing
Gatorman
Post by Gatorman » Sun Mar 20, 2022 5:56 am
@RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
Post by RESET_9999 » Sun Mar 20, 2022 12:59 pm
Gatorman wrote: Sun Mar 20, 2022 5:56 am @RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
when you manually edit L5. You enter just 260...
in manual modes, it only edit top/bottom which means if your video has right and left borders, you have to use the AUTO-L5 workflows.
The new version that I'll upload today will include:
- Support input files with space and special characters
- New workflows that fix invalid L6 metadata in some p5 web-dl (> 10 000)
- New workflows that can remove HDR10plus when injecting DV ( for the firestick TV)
- Now the output filename will be the input filename instead of just " P8.hevc"
rosavanwinkle
Post by rosavanwinkle » Sun Mar 20, 2022 5:19 pm
My god this thread is still going even after maybe 2 years of being inactive on it...
so if i wanna convert my raw blueray files with dolby vision to a single layer what is the best use atm?
It is for use on a shield tv pro with plex and a LG tv
i used to use yuescope tool,but is their something else out their now or something better?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Gatorman
Post by Gatorman » Mon Mar 21, 2022 12:14 am
rosavanwinkle wrote: Sun Mar 20, 2022 5:19 pm My god this thread is still going even after maybe 2 years of being inactive on it...
Checkout the links within the signature of RESET_9999's post above yours.
jayper
Post by jayper » Mon Mar 21, 2022 4:29 am
Has anyone done a P5 to BD remux for West Side Story? I am measuring the top and bottom L5 areas and I have checked it 5 different times. My eyes may be deceiving me, but I am not getting equal numbers for the top and bottom areas.
Measuring 280 for the top and 276 for the bottom. Am I losing it?
Post by RESET_9999 » Mon Mar 21, 2022 11:21 am
jayper wrote: Mon Mar 21, 2022 4:29 am Has anyone done a P5 to BD remux for West Side Story? I am measuring the top and bottom L5 areas and I have checked it 5 different times. My eyes may be deceiving me, but I am not getting equal numbers for the top and bottom areas.
the dv web-dl is not cropped so it probably already has proper L5.
you only have to edit L5 when the web-dl is cropped.
I dont have this movie remux but if i look at the scene encode, it's 1608px so 276/276
rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 11:35 am
Gatorman wrote: Mon Mar 21, 2022 12:14 am
thanks for the info great help.
i went to get the specific tsmuxer that yuescope linked us but euhm the link shows me to a strange website without any download
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Mon Mar 21, 2022 12:29 pm
you don't need tsmuxer for the Shield. Use Mkvtoolnix or makemkv
rosavanwinkle wrote: Mon Mar 21, 2022 11:35 am thanks for the info great help.
rosavanwinkle
Post by rosavanwinkle » Mon Mar 21, 2022 12:45 pm
RESET_9999 wrote: Mon Mar 21, 2022 12:29 pm you don't need tsmuxer for the Shield. Use Mkvtoolnix or makemkv
thanks again for that info,will version 53 of mkvtoolnix work? last time i checked it did i think... its because i have a seedbox and they cant ugprade it atm beyond version 53 :/
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
jayper
Post by jayper » Mon Mar 21, 2022 2:13 pm
RESET_9999 wrote: Mon Mar 21, 2022 11:21 am
I appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
I am still a bit confused... Perhaps I'm misinterpreting things, but the version I have is cropped, meaning there are no black bars in the web-dl. The resolution is 3840x1606. I just demuxed it again and extracted the RPU, and when reading the RPU there is L5 section and no active area offsets. Perhaps I am missing something, or I got a bad release? Thanks again.
Post by RESET_9999 » Mon Mar 21, 2022 2:18 pm
jayper wrote: Mon Mar 21, 2022 2:13 pm I appreciate your responding and all the time you've put into this thread and the tools! Much appreciated.
Ah I didnt know there was another p5 web-dl version. Then yes you have to edit L5.
the webdl i was talking about:
Format : HEVC
Format profile : Main 10@L5.2@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 2 h 36 min
Bit rate : 23.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.117
Stream size : 25.3 GiB (97%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2022-03-02 18:06:45
Tagged date : UTC 2022-03-02 18:13:15
Color range : Full
Codec configuration box : hvcC+dvcC
