More choices
Onlyme
More choices
Can you add the option to add more than 1 file per time?
For example add a full folder of for example mkv files with dts sound.
If you can add this option/feature please add it at the next version of the program.
Reason: Locking because because participants are not moving the discussion forward
Re: More choices
A full folder?
How are you using MakeMKV? You can select all the titles on a disk.
Or are you using MakeMKV to do the functionality of ffmpeg? That is, converting audio instead of ripping disks?
Onlyme
Re: More choices
Add files and re-encoded for audio mostly.
To convert dts-hd or dts into aac(Don't have the ac3 option).
So...
So...
Re: More choices
OK, if the MKV files are already on your hard drive with their "regular" audio tracks, ffmpeg will give you maximum flexibility for converting. ffmpeg is already the tool within MakeMKV that is doing the conversions, but you don't have access to all of it's flexibility. Its libraries also drive handbrake's audio conversions, so it's a useful tool to have.
Onlyme
Re: More choices
Yes it is at the hdd.
And how i can add some audio profiles and why don't work when i try to convert an mkv file with flac audio codec?
Re: More choices
I have very little information to work with on this, since you are dealing with potentially random MKV files. I know that many things MakeMKV does are based on how things are on physical media; I do not know which ones apply to existing MKV files, since I've never tried them.
Other tools make more sense for that. There is no need to create a special profile to use ffmpeg to convert audio.
The profile defines what conversions are AVAILABLE, and you select the tracks to save. That can be through manual selection, or a selection rule.
Onlyme
Re: More choices
Yes you need to add some profiles if you want to convert for example into ac3 or into mp3.
As it is the makemkv 1.16.7 now you CAN'T convert any audio into ac3 so.......
It need more profiles.
Re: More choices
As far as modern VIDEO playback, MP3 is almost a dead format.
Your "needs" for MakeMKV seem like you are upset that your car is not also a pickup truck and motor home.
Onlyme
Re: More choices
I believe you don't even read what i write exactly.
I write mp3 AND AC3 so...
Ac3 is a dead format to???????
So please when you answer to a post please read it before.
Re: More choices
And I say, "read what is recommended".
You seem unusually adverse to the idea of using the proper tools for the job.
A free tool exists for exactly the job you are wanting to do. But you insist that MakeMKV must change because you do not want to use the proper tool.
Onlyme
Re: More choices
Doesn't matter at all how anyone use the program.
From the time that the program itself OFFER YOU that option(To add files and re-encoded) to the profiles it has you can use it as this so....
THERE IS NO RECOMMENDED USE FOR ANY PROGRAM????????
Chetwood
Re: More choices
You've been quite patient with this clown, Woodstock.
Onlyme
Re: More choices
If you LEARN TO SPEAK KID then i will read your post.
That kind of posts simply i IGNORE THEM
