Re: SDFtool Flasher
#496 Post by MartyMcNuts » Mon Mar 14, 2022 1:38 am
Bilbo wrote: Mon Mar 14, 2022 12:23 am
MartyMcNuts wrote: Sun Mar 13, 2022 9:14 pm
Bilbo wrote: Sun Mar 13, 2022 5:32 am Hi, thanks for the tool!
I'm trying to read/play/rip UHDs
forgive me if I missed the answer, I combed through 33 pages.
me:
Win10 x64 (administrator)
Model: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MOEL91I1100
https://www.amazon.com/gp/product/B07BC9F98J/
the Archgon.
connected via USB. Slimline.
Firmware chosen: DE_LG_BU40N_1.00
results:
"Command produced error code 0x8f052603"
please help
Make sure there is no disc in the drive and the tray is closed.
Make sure you using the latest version of the SDFtool flasher, which does detect the Archgon 1.02 firmware as encrypted.
You can't flash 1.00 directly. Flash to 1.03-MK first, then flash to 1.00.
flawless victory!! Woooo I'm now watching the 1st 4k UHD blu-ray title I've ever purchased! Worked great, thanks again guys for all your help!
P.S. For this drive, should I stick w/ this firmware as-is, or is there another cross-type I should flash w/ (to get faster reads of UHDs?)
Thanks again!!
I recommend 1.00 as it is the most software compatible.
mwtimken
Re: SDFtool Flasher
#497 Post by mwtimken » Sat Mar 19, 2022 8:54 pm
Getting an input string format error when I select my ASUS drive (see attachment).
The popup lets me continue on, but I'm leary of pulling the trigger on drive flashing after the error.
Note: there is no status on the 'Encrypted Firmware' field (after selecting the ASUS drive).
Regards,
mwtimken
Re: SDFtool Flasher
#498 Post by MartyMcNuts » Sat Mar 19, 2022 9:43 pm
mwtimken wrote: Sat Mar 19, 2022 8:54 pm Getting an input string format error when I select my ASUS drive (see attachment).
Regards,
mwtimken
Ok, it looks like SDFtool Flasher is having trouble with the encrypted firmware check for the ASUS drive. I'll look into that. Please use the old version in the meantime.
mwtimken
Re: SDFtool Flasher
#499 Post by mwtimken » Sat Mar 19, 2022 10:01 pm
Okay, used the older version and I'm off and running. Flash was okay, doing some 4k ripping now :D
Thanks for getting me going!
Regards,
mwtimken
Re: SDFtool Flasher
#500 Post by MartyMcNuts » Mon Mar 21, 2022 1:46 am
Hello all,
The SDFtool Flasher has been updated to version 1.3.3. This update fixes the encrypted firmware detection issue affecting ASUS drives. Download link in the first post has been updated.
JonJonXD
Re: SDFtool Flasher
#501 Post by JonJonXD » Tue Apr 05, 2022 2:14 am
MartyMcNuts wrote: Mon Mar 21, 2022 1:46 am Hello all,
Hi friend,
I am a LONG TIME MakeMKV user (legacy permanent license over here) and I just wanted to THANK YOU for the hard work you put into this updater.
I am starting to pick up 4K blurays and was concerned that I would need to purchase another bluray drive, but your work made it so I did not have to.
So far, I confirmed that my drive still works (LG BP50NB40 upgraded to the 1.03 MK firmware), so I am excited to test out my new 4K discs coming in :)
Keep up the great work and THANK YOU AGAIN!
Re: SDFtool Flasher
#502 Post by MartyMcNuts » Tue Apr 05, 2022 11:11 pm
JonJonXD wrote: Tue Apr 05, 2022 2:14 am
Hi friend,
You will need to cross-flash it as BP50NB40 firmware is not UHD capable. For the BP50NB40 to be able to rip UHD, the recommended firmware is BP60NB10 1.00-MK or BU40N 1.00.
JonJonXD
Re: SDFtool Flasher
#503 Post by JonJonXD » Sat Apr 09, 2022 7:45 pm
MartyMcNuts wrote: Tue Apr 05, 2022 11:11 pm
Hi friend,
Thanks, friend!
Before I came back, I had figured that out. I have had no issues cross flashing the BP60NB10 1.00-MK firmware :).
peters
Re: SDFtool Flasher
#504 Post by peters » Wed Apr 13, 2022 11:12 am
Hi guys,
at first, sorry for my questions and my horibble English.
I`m newby and I need to help with flashing my new drive. As I read on UHD flashing guide updated 2022, I`ve bought slim drive LG BU40N and Vantec NST-510S3-BK 9.5mm slim sata case.
SDFtool flasher v1.3.3 show HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MO5KB3H0719
I`ve downloaded mk-firmware-pack-20200720, where is located some firmwares for this drive. Folder BU40N-N-Main contain a HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
I don`t understand how to find right fw for flashing.
MartyMcNuts wrote to Bilbo (page 34) that first must flash firmware to 1.03-MK and next steps is flashing to 1.00. But when I`ve downloaded a MK firmware pack from first page of this thread, ther isn`t any 1.03-MK firmware. There is only fw which I mentioned above.
Please, which one is right for me? 1.03MK (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin) or HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MO5KB3H0719 ?
Without this information I really worried do anythig with drive. I won`t to destroy it. Please help me.
Thank you for any advice.
Re: SDFtool Flasher
#505 Post by MartyMcNuts » Thu Apr 14, 2022 3:26 am
peters wrote: Wed Apr 13, 2022 11:12 am Hi guys,
BU40N 1.03-MK is in the "MK\old" folder of the MK firmware pack.
peters
Re: SDFtool Flasher
#506 Post by peters » Thu Apr 14, 2022 5:56 am
thank you very much for answer.
I`d like to ask you again to the same thing.
Please, what is your reommendation for first step. 1.03-MK or newer 1.04-MK?
Before first flashing may I mark "Encrypted Firmware" or not mark?
Many many thanks.
Re: SDFtool Flasher
#507 Post by MartyMcNuts » Thu Apr 14, 2022 10:28 pm
peters wrote: Thu Apr 14, 2022 5:56 am Hi,
Many many thanks.
1.03-MK as first step. SDFtool Flasher will automatically perform encrypted firmware check and apply flag if needed.
Jellyfan
Re: SDFtool Flasher
#508 Post by Jellyfan » Mon Apr 18, 2022 12:40 am
Hey MartyMcNuts (and everyone else involved in helping flash drives),
Just wanted to say a huge thanks for your work. I replaced my old 2013 WH14NS40 with a WH16NS60. My firmware flash wasn't as straightforward as it could've been, so here are some details for future readers:
I'm on Windows 7 Pro, so the latest version of the SDFtool Flasher failed to launch with a message of "The program can't start because api-ms-win-core-winrt-l1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem." I see another user ran into this problem back in 2021, but when they asked about it, no one answered. So, I tried using the older version (v1.2.0). When I tried writing HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin to the drive I got an error message saying it couldn't read the .bin file. When I clicked OK... ...it uh... ...wrote the firmware to the drive anyway. The whole process felt a little sketch, but when I tried to rip a disc I couldn't rip with my old drive, it ripped great! (Lord of the Rings: Fellowship of the Ring Extended Edition part 1).
So, I hope nothing crazy went wrong that I'll never know about, but given that the drive is ripping successfully... ...all's well that ends well?
Dennis371
Re: SDFtool Flasher
#509 Post by Dennis371 » Tue Apr 19, 2022 3:28 pm
I used the flasher that you made and worked great. Thank You
Dennis :D
cranks
Re: SDFtool Flasher
#510 Post by cranks » Wed Apr 20, 2022 12:00 pm
Thanks heaps for the Flasher tool.
It worked a treat for my Archgon external drive!
