I have a problem with ripping TRUE_HD Dolby Atmos tracks. When remuxing the MKV to a Blu Ray Folder I get the warning "MLP codec is not standard for BD disks, the m2ts will not play on a Blu-ray player". The BD then doesn't play the movie when on this audio track. After changing to a different audio track it plays perfectly. The MKV plays perfectly on Kodi. The via Handbrake shrinked MKV including the passthrough TRUE HD track put on a BD is not playing on my Sony Player and the XBOX until I change to a different audio track. Then the movie again plays perfectly. What is my problem here, can anyone help?
Re: MLP codec is not standard for BD disks
You must convert the True Atmos audio file with useac3to before muxing.
Failure26
To AC3 or E-AC3?
hansolo
On BD format TrueHD audio must include legacy core ac3. It is mandatory! Typically backup softwares e.g. MakeMKV remove this core part when matroska is chosen output format as it is considered redundant.
Use
A core part will be re-encoded and interleaved to existing TrueHD only track. After this audio track is Blu-ray compatible and can be used as an asset e.g. in tsMuxeR.
Use
eac3to source.thd target.thd+ac3LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
Failure26
Now I got it. Thanks a lot!hansolo wrote: Fri Mar 18, 2022 10:26 am On BD format TrueHD audio must include legacy core ac3. It is mandatory! Typically backup softwares e.g. MakeMKV remove this core part when matroska is chosen output format as it is considered redundant.
UseA core part will be re-encoded and interleaved to existing TrueHD only track. After this audio track is Blu-ray compatible and can be used as an asset e.g. in tsMuxeR.Code: Select all
Newbie5678
As you can tell by my username, I'm new to all of this. Thanks to this thread, I understand my problem with trying to create a Blu-ray folder from an MKV file and the fix. In which file do I insert the code to include TrueHD+AC3?
